Question about Nolo Dealing with Problem Employees: A L (1260150SF)
Toshiba 53HX71 Proj CRT television - colors missing with HD only
Hi ! Recently bought this TV used from a friend. Analog interfaces work good. When I try to use the any one of the 2 Colorstream interfaces, the video is there, but it is like some colors are missing, and the pitcure is very dark. It is not a problem with a bad cable box or a bad DVD player, as the previous owner had the same problem. I am pretty knowledgeable with electronics and know how to solder electronics. Can anybody help at least narrow down what may be faulty ?
  • McQuyver Dec 02, 2008
    i have a red colar tube that developed a problem over night the pic. is warped beyound adjustment. the bottem third looks like a rolling wave of ghosting . I have removed the power, bled the capaciter off, leveled the lens and tube pack and removed the outer lenses. under the red convex bottom lens,(the one sealed in fluid), there is what looks like a film which i can see lookes like it is warped which explains the wave. My question is can this film, which appears to be flexible be replaced, and if so what is the fluid that i am guessing works like a coolant. and wher to get replacement fluid. Or do I have to just replace the whole tube. any help on this subject would be helpfull. thanx...
    Scholar:
  • 125 Answers
DANGER I take it you understand that these can kill. Even WEEKS after they have been unplugged. The chassis can be HOT on them too, what is normally considered to be EARTH can be live with thousands of volts. Bleed the capacitor down first, using the right resistors, use rubber gloves, boots and stand on a rubber mat. Keep one hand in your pocket to avoid current going through your heart if you mess up. This is just how I do it since a near miss. Check out precautions yourself, from a reputable source if you still wish to try. Now that I have said that, it may be connections on the inside of the Colourstream interface. Sounds like you have dropped a colour and have another problem that could well be related. ie: two wires touching or shorting.
Posted on Apr 28, 2007
Toshiba 50HDX82 50 in. Rear Projection Television-HDMI to my TV?
Hello
You have to buy one converter box. Your TV does not accept or process HDMI signals.
Dec 08, 2011 | Toshiba 50HDX82 50" Rear Projection...
My Toshiba 53HX71 takes about 20 minutes to "warm"
This is a symptom of poor solder connections inside the set. The set will continue to deteriorate until it won't turn on at all. This is essentially a labor only repair and should not be to expensive for any TV service shop. Once this has been repaired, the set should work for many years to come.
These poor connections are caused by the continual heat/cool cycles because of use and is normal.
Dan
Apr 09, 2011 | Toshiba 53HX71 53" Rear Projection...
Is this model HD ready?
Yes,this tv is able to play HD signal,but must have pay cable or satellite signal hook it up to it.This tv is CRT-(tube tv) analog design tv,antena alone will not work without a converter box.
Feb 17, 2011 | Toshiba 50A50 50" Rear Projection...
Convergence issue Blue not convering correctly, but the other colors do. The blue is warped at the top and bottom of the screen. Is this problem something that can be fixed?
Yes,the covergence ICs and precision resistors can be replaced to rebuild the area. A reputable shop may charge around $300 . If you are technical person,I can guide you further to do yourself!
Jun 04, 2010 | Toshiba 53HX71 53" Rear Projection...
I've got a toshiba 53hx71 that the screen rolles when the tv is on in the video inputs or the ant inputs. when there is nothing on the tv it has red squigle marks on the black screen. When you watch a...
Most of the time the Hyper Board failing is the cause of this problem. It will eventually get worse where it also affects the HD ins. Unfortunately the Hyper Boards are no longer available from Toshiba and have not been available for quite some time. My suggestion is to coast with it and replace the Set when the HD ins fail.
Sky Assoc
Nov 24, 2009 | Toshiba 53HX71 53" Rear Projection...
We have a Toshiba HDTV model number 57H82. It is
Sounds like a bad tuner/decoder on the Qam analog side of things. You can bypass this with a Clear qam converter box or a analog to digital tuner box or simply having this repaired upwards of $200 bucks.
Thanks for using Fixya.com
You're Toshiba Tv Expert.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Toshiba 57H82 57" Rear Projection...
RCA REAR PROJ. SCREEN BOWS AT TOP AND COLORS DOUBLED
Hi, thank you for visit fix ya.
Resolder all connections around fly back ( check for open pico fuse).
if still problem, replace convergence board.
Thank you
Jul 27, 2009 | RCA HD52W58 52" TV
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Color 'bleeds' or smears when watching HD channels on Toshiba 53HX71
Sounds like the same problem i had recently, Take the front off, (its safe so your ok) You will see the 3 lenses which are ajustable, Just keep adjusting 1mm at a time until it solves this, Took me about 45 mins to get it perfect, Persist and you will get there!! Hope this helps
Mar 17, 2007 | Toshiba 53HX71 53" Rear Projection...
No brightness for Colorstream either connections
Sounds like a bad coupling capacitor in the luminance "y" signal processor circuit. Use a schematic of the tv and a osciloscope to find this problem.
Jan 31, 2007 | Toshiba 53H71 53 in. Rear Projection...
Nolo Dealing with Problem Employees: A L (1260150SF) Logo
Top Nolo Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Nolo Computer and Internet Expert? Answer questions, earn points and help others
