Question about Miele Kitchen Ranges
THE DA 446, DA446EXT COOKER HOOD REQUIRE TWO MOTOR?
I purchased the DA 446, DA 446 EXT cooker hood, but it does not haveany motor. Does it need two motors or can it run with one and do youstock this motor.
Please advice
Thanks
N.Razaq
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Contact Miele.
Posted on May 06, 2017
  • 1462 Answers
SOURCE: rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
Posted on Jun 03, 2007
SOURCE: the light on my cooker hood comes on but motor
It's probably a bad fan switch or a loose/corroded/broken electrical connector in the fan circuit. Another possibility (but not as likely) is the fan motor has failed.
Posted on Apr 21, 2009
SOURCE: belling cooker hood chim101 BL - light/ lamp
mrsomuch is almost right, its the steel cage which surrounds the glass that you have to gently prize out.
Graham
Posted on Aug 12, 2009
hiltonjug
  • 612 Answers
SOURCE: range hood blower motor - rangemaster
I'm not sure if it a regular home range hood but if it is. Check the price of a new one. A regular home range hood cost around $100.00 and a fan motor runs around the same. If it a commercial type is another story. If commercial Heritage Food Service Equipment will have the motor.
Posted on Oct 01, 2009
  • 8404 Answers
SOURCE: Problem with cooker hood
Filters clean? Fan running? No clogs in the exhaust?
On the one hand, you want the disagreeable stuff out of the kitchen - on the other hand, you want to keep your heated or cooled home air to stay inside.
Posted on Mar 09, 2010
Cooker hood installation
A cooker hood needs to done by a competent qualified Electrician but basically depending on your surface of the cooker hood.Depending on the type of cooker hood you have(extract or outside) If it is a extraction (meaning you are using filters and not connected to a vent) The Electrician needs to connect the electric to a point or spur via a power switch on the wall which when you fit up the main part of the hub covers the spur. after that you need to measure and fit the cooker hood to your requirements but make sure your walls can support it and mark off the holes before drilling or check the walls for electric wires in terms of safety.
May 21, 2012 | Washing Machines
Hygena APP2500 cooker extractor hood?the lights on the hood work but the extractor itself does not work, is this likely to be the motor that needs replacing or the switch unit ? Plz advice
if u have a meter u can check the switch and the motor,By putting it on the continuity mode and check to see if u have a bad motor or switch
Apr 02, 2011 | Dryers
I'm looking for a new, replacement pot for an old slow cooker.
Follow this link to purchase available parks for your slow cooker.
www.focuselectrics.com/catalog.cfm?dest=itempg...54
Regards
Alan Hood
ami-man
UK
Jul 01, 2010 | West Bend 84356 6-Quart Slow Cooker
Need the glass hood for a Miele DA289 Range hood
hi,
you can only purchase Miele spares from Miele or through a Miele service agent. have a look on the Miele website for your nearest Miele branch
May 13, 2010 | Miele DA 289-4 Kitchen Hood
Mar 09, 2010 | Rangemaster Kitchen Hood
Am buying a Bosch cooker hood - does it come with filters?
filters required only if you are venting inside your house (ie recirculating the air), if it is going outside, then you don't need them.
Jul 26, 2008 | Bosch DKE 9306 / DKE 9302 / DKE 9307...
Kitchen Ranges Logo
78 people viewed this question
Top Miele Kitchen Ranges Experts
Jim Thurston
Are you a Miele Kitchen Range Expert? Answer questions, earn points and help others
