Question about Pentax K1000 35mm SLR Camera
My pentax k1000 has a black splotch in viewfinder, does not show up in images.
When I look through the viewfinder there is a black splotchy spot in the middle of the frame. It does not show up on the negatives but it is quite an annoyance. Does anyone know how to fix this, if it is fixable?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
It would depend on exactly where the splotch is. If it's on the outside of the viewfinder, you could simply clean it off with a damp cloth (and maybe some Windex or Formula 409). If the eyepiece is damaged, you can order a replacement part here.
Remove the lens and look at the mirror. If their is something on the mirror, you can carefully clean it. The mirror is very sensitive and vulnerable to scratching. If the reflective coating has been removed then you'll need a new mirror.
Look up at the bottom of the focusing screen. That's the more-or-less clear piece of glass that the mirror will reflect light from the lens onto. If there's a splotch on the outside, you can clean it off.
Those are the parts you can get to. If the splotch is on something on the inside, then you'll have to take the camera to a good camera shop to have a trained professional disassemble and clean it.
Posted on May 23, 2012
5 Suggested Answers
SOURCE:
Obertelli
  • 3006 Answers
SOURCE: on my pentax k1000 the black fuzz looking stuff
That's the mirror bumper, it softens the blow and cuts the noise as the mirror flips up.
Carefully remove it and then replace it with a new one. You can get it as part of a foam light seal repair kit for your camera; this also ensures that the sticky black goo which used to be foam and which prevents light from getting past the edges of the camera back gets replaced. Light seal kits are very cheap, and if you buy a pre-cut version then it makes a fiddly job a bit easier and potentially less messy. They're widely available on sites like ebay, just search for "k1000 light seals" and check that the kit includes a mirror bumper/buffer.
If you don't get it repaired the fuzz will get everywhere and can also get onto the film surface causing white spots on your photos or black spots on negatives/slides. The debris can also get into your lenses so remove it asap. Gooey foam light seals are even worse as it's both corrosive and abrasive (due to the grit it attracts) and gradually migrates to gum up the works. It can also result in light fogging on your photos (usually seen as red streaks from the top or bottom of the picture). Modern foam seals do not decompose like the old ones did.
I hope that I've helped you, please take a moment to rate my answer.
Posted on Mar 02, 2010
mail541
  • 58 Answers
SOURCE: Pentax A3000 frame advance jammed
There could be a number of causes.
First make sure that the replacement batteries are up to it. Ie one's marketed for camera use. Others often cannot supply the current required by the motors. (Electric motors require most current just as they start, and so it may not do anthyhing at all.) Then check the battery contacts are clean. Much the same reason applies, dirty contacts cam prevent the batteries from supplying enough current.
One more simple possibility is that it does not know the battery door is closed. This may be detected by a protrusion in the film door edge operating a contact in the loctaing groove, or contacts in the door latch. There may be more than one!
It is also possible that the camera is detecting an impossible film. DX coded film uses the contacts inside the film chamber to read the film speed from unpainted sections of the film cassette. It is just possible that a dirty contact or a scratch in the paint is telling the camera that the film is a speed it cannot handle, or is just confusing it with a nonesense code!
Outside these there are a number of possibilites which will require internal investigation. You can try these camera repair pages for tips on repairing your own camera.
Posted on Jan 23, 2009
  • 185 Answers
SOURCE: Can't get my lense off!
You can use any mm lens you want as long as it was made to fit the K1000.
Is the lens a Pentax lens ?
Push the lens release button down and turn lens Clock-wise then while holding release button down quickly turn lens counter clock-wise, it should come right off.
If it did not then it must be disassembled to remove the lens.
Posted on Dec 07, 2008
Obertelli
  • 3006 Answers
SOURCE: my shutter is sticking; half of the picture is black
This is not a user repairable problem.
You need to take it for a professional repair. The good thing is that this is an all mechanical SLR and was designed so that repairs are usually straightforward. Spares are no longer available, but so many of these cameras were sold and are still in use today that many repairers have a few scrap examples which they can cannibalise when needed.
Given that you can buy a perfectly good used K1000 at online auction sites for between £30-£40 it may not seem like an economical repair, but newly serviced ones with a guarantee sell for over £100 so it's definitely worth it for such a superb classic SLR.
Posted on Jul 10, 2009
Film cartage broke missing parts
To repair this camera will be well over $100; my opinion not worth it. You would be better served purchasing another camera of the same type from ebay. An alternative terrific camera is the Pentax K1000, better yet K1000 SE. The SE has a split viewfinder, easy to focus. The K1000 have microprism that are more difficult to focus with especially in lower light; need good eyes. Then there is the Pentax K2, that at the time was their top of the line camera. All three cameras can be purchased for about $100-ish. Most will come with the Pentax 50mm f/2.0 lens.
Feb 06, 2014 | Minolta Photography
Viewfinder blurry Pentax K100
The image is directed by the lens to a mirror then to a prism then to the viewfinder. The mirror flips up when you take a picture so the image can reach the film behind it. If the lens is ok it is possible that the mirror is very dirty or not returning completely to the proper position after a picture is taken. If the mirror is dirty you should have it professionally cleaned because it is a very light weight metal mirror and VERY EASILY SCRATCHED. If you have another lens then mount it and see if it is also blurry and cannot be focused.
A few cameras like certain Olympus models have a mirror lock up option which you use after focusing the image while the camera is on a tripod. This gets rid of the slight vibration caused by the mirror swinging up out of the way while taking. a picture.
If all else fails you might consider taking it to a good camera shop if you can find one.
Digital cameras are getting better and better but there are still things film cameras can do that most digitals cannot. Long exposures in "Bulb" mode and multiple exposures are among these. Also each brand of film has it's own Artistic color expression such as Afgachrome vs. Kodachrome.
Jul 16, 2013 | Pentax K1000 35mm SLR Camera
My tv has black splotches or pools on the bottom
If the splotches are a shawdowy black and look like mold growing between the Lens, its most likely dirt or water spots on the bottom of the large mirror. I cleaned mine and missed a few water spots on the bottom of the large mirror and the splotches (spots) showed on the screen. Other than Dirt, or water spots, There is nothing else that I can think of that would cause this. Unless the Someone has cleaned the screen and it soaked up between the lenes. But it Takes about 30 minutes to disassemnble, give it a good cleaning and put it back together.
Nov 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My Pentax KX (analog) wont show apperture in viewfinder. Maybe something block the apperture window. What should i do?
There is a tiny mirror to reflect the f stops to the view finder.
Either this tiny mirror fell off or the needs adjustment.
You have to take out the top cover to have the access to this tiny mirror.
Jun 25, 2010 | Pentax K1000 35mm SLR Camera
On my pentax asaih k1000 when you look through the lense its black- i dont know if the mirror might have fell out or what...
If you look through the view finder and it is black, the mirror is hanged up and the shutter is jammed. The mirror is still there.
May 31, 2010 | Pentax K1000 35mm SLR Camera
On my pentax k1000 the black fuzz looking stuff
Mar 02, 2010 | Pentax K1000 35mm SLR Camera
Will no longer recognize 4gb sd cards
F4shsk1
are you sure the camera is a Pentax K1000.
the K1000 is a manual 35mm film camera, the only electronics in it are for the light meter. plus a circuit for the flash connections.
Apr 14, 2009 | Pentax K1000 35mm SLR Camera
Pentax K200D NO LCD just viewfinder visual
Pentax K200D is a SLR Digital Camera..... in SLR you can the images in LCD after it has been taken.... while cliking image you need to use the Viewfinder......
Mar 24, 2009 | Pentax K200D Body only Digital Camera
Black bar on rt. side of photos.
elockepens
is this black bar on all the time or only when using flash? if only when using flash then your shutter speed is to high. for flash on the K1000 the shutter speed must be 1/60th sec. or slower.
if the black bar is there all the time then the shutter must be adjusted, cleaned and lubed.take or send your K1000 to a camera repair shop for an estimate first as there are no new part available,
Feb 02, 2009 | Pentax K1000 35mm SLR Camera
Pentax K1000 35mm SLR Camera Logo
1,567 people viewed this question
Top Pentax Photography Experts
Bill Eager
Geoff Hone
Are you a Pentax Photography Expert? Answer questions, earn points and help others
