Question about Onkyo 630-Watt 7.1 Channel Home Theater Speaker
7.1 channel onkyo home theater -- no sound out of subwoofer
Unless I run the setup with the microphone, then sounds comes out. Seems like there is no LFE channel on what I am playing? if that is the case what does have a LFE channel?
    Problem Solver:
  • 15 Answers
You might try different listening modes; Some modes (Direct, DTS, Dolby - though I'm not sure which, offhand) require a seperate LFE track for sound to be output by the subwoofer.
Posted on Dec 02, 2008
  • theCybe Dec 02, 2008
    *Also, set your speaker sizes to 'Small.' When they're set large, only frequencies not sent to your mains will play through the LFE.
    Audessy suggests always using 'Small,' unless you don't run a subwoofer. Unfortunately, Audessy almost always selects 'Large.'
Audio problems with HT-S7100.Sound only comes through center speaker and subwoofer. Sound is very tinny. Zone is off and can't be turned on.
Hi Tori,
Not sure if this has been resolved for you. If it has not please email me the units serial number along with a copy of the dated sales receipt so that I can see what options I have for you. Please email me at askOnkyo@us.onkyo.com, Thanks, JT
May 10, 2015 | Onkyo home theater system HT-S7100 User...
I have purchase onkyo 5.1 channel home theater but i am not able to hear sound from rear speaker when a and b speaker setting toggled and subwoofer effect also not getting
The 2 front speakers need to be connected to 2 big banana plug/screw connection marked Speakers A and not the last 2 color coded Push in style connectors,I had the same issue and this was the fix.Look at the quick setup guide closely,I did not look at it close enuff also.
May 24, 2011 | Onkyo HT-S3300 Theater System
Subwoofer turns on and is hooked up, but no sound.
The signal don't seems to be present to the sub input.
Try change the wire betwen the audio system and the subwoofer.
Spider Guy
Mar 15, 2010 | Onkyo 630-Watt 7.1 Channel Home Theater...
I get no bass sound from sub-Woofer connected to Yamaha RX-V465
Check your speaker settings in Setup menu / Speaker Setup / Manual / Config (and then in this submenu also Equalizer).
In Config, choose where should low frequency sound go - subwoofer and/or front speakers (if they are big enough). The settings are: Bass Out: SWFR/Front/Both.
Also check Subwoofer phrase in SWFR Phase.
Check settings of all speakers, they can be Large / Small / None. If small, frequencies lower than "Crossover" settings, will not be put on them.
Nov 13, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Home theater
Just go into your sat box setup menu and under setup system option select audio and make sure to go to the dolby digital option and turn it on. This feature is turned off by default from the factory. You will always get 2 channel sound unless that is on. Also remember to go to a hd channel as they are broadcast in surround sound and non hd channels are broadcast in 2 channel.
Nov 08, 2008 | JVC THD-50 System
JVC th-m505 and dish network box sound level control problem
It's not your receiver, it's the Dish Network equipment, I have the same issue with my Onkyo...unfortunately I'm still researching the solution.
Oct 30, 2008 | JVC TH-M505 System
Need help understanding microphone
as described in the owners manual, set the microphone at the primary listening position at ear level, prop it up somehow, a camera tripod works well, plug the mic into the receiver front port, near and under volume dial, and follow instruction on the receivers screen.
Jun 04, 2008 | Onkyo HT-SR800 System
Problem w/ surround sound for Onkyo HT-R430
you are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Dec 31, 2007 | Onkyo HT-S680 System
Subwoofer volume and sound
i had the same problem when i tried to adjust speaker output levels, distance and equalizer manually without using audessy setup..so i reset everything to factory setting (0s)..and then ran
audessy setup..reduce volume on your subwoofer to slightly above minimum(behind the subwoofer) before running the setup..once audessy setup is completed successfully..i started changing setup
manually..changed speaker config for front speaker to small (it is set as large by audessy setup), this should automatically adjust center and other speaker configuration (if not make sure to set them to small as well), then set the cross over frequency to 120..increase the volume on your subwoofer and now you should hear it fire..if this does not help..try playing some rock music with all channel streo mode..if your subwoofer does not fire even for this..then take the system back for exchange..
Dec 28, 2007 | Onkyo HT-SR800 System
Jensen Subwoofer JPS-10
This sound is made by the automatic shutdown in the speaker. Jensen repaired my unit under warrantee.
Aug 27, 2007 | Jensen JPS10 Subwoofer
Onkyo 630-Watt 7.1 Channel Home Theater Speaker Logo
361 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
