Question about Viper Security and Remote Start System (basic install included)
After i start the car with the remote start, then get in the vehicle and turn the key to on, the only way to get the vehicle to shut off is by pushing the button on the remote what can i do to solve this??
  • Dan May 11, 2010
    Who installed this unit and did they hook up the brake wire?
    New Friend:
  • 28 Answers
This is not a basic unit install so be careful of bad wiring wish can cause fire so its best you use a professional installer,and depend on the year of your vehicle you may need a by pass module for your vehicle
Posted on Dec 04, 2008
Mars 22 car starter. car starts for a second then turns off
Your truck most likely has a chip in the key. You will need to contact the maker of the remote start kit you have and see if they make a kit to bypass the chip key.
Nov 20, 2013 | Omega MARS-22 Remote Vehicle Starter with...
My truck wont start when i use the remote. the power in the tuck turn on but the truck never turns over. 2006 ford f-150
Sounds as if your immobilizer bypass is malfunctioning. To test, remote start vehicle. Check vehicle cluster (gages). If the immobilizer bypass is the issue, there will be car/lock symbol flashing rapidly. To confirm, put the key in the ignition(do not turn), remote start the vehicle. It should start. If the vehicle starts, remove key, remote start again without key. If the vehicle does not start, have the immobilizer serviced. If the vehicle does not remote start with the key in the ignition, the issue may be with the remote starter's starter output.
Jul 25, 2011 | Prestige Remote Start
2007 mercury grand marquis, has auto remote start. car started normally with key,then when i pushed brake pedal car stalled. now car will not turn over or start back up. when i turn on ignition nothing...
What brand is the remote start, and is it new to the vehicle or has it been on and working properly for a while?
Most remote starts have a feature that will shut the vehicle off when the brake is applied after the vehicle was started with the remote and the key has not been used to turn the ignition. However this is not what happened in your case. Some remote starts have an on/off switch that is installed under the dash, depending on brand and installation. If you have that switch, turn it off. If this does not correct the problem, locate the power with for the remote start and disconnect it. If this still doesn't correct the problem then is sounds like it has caused other electrical issues.
Dec 28, 2010 | 2007 Mercury Grand Marquis GS Sedan
Try to start my 06 rx8 with car starter and only my dash lights go on then shut of 3 times without my car turning over. The key port is also locked.
It sounds like the bypass module is not bypassing. The next time that you attempt to remote start the vehicle, look at the cluster for a flashing key. If there is a key inside a car flashing...your bypass module is not functioning.
Nov 29, 2010 | Remote Start System
Key will not shut vehicle off after staring with viper starter
The brake is what shuts it off. To keep the car on You first put key in to IGN position then hit the brake. If you hit brake first then the remote start shuts off
Nov 24, 2009 | Remote Start System
Vehicle will not shut off after key is removed.
try starting it with the key and then try to shut it off with the key...
Jan 10, 2009 | 2003 Chevrolet Tahoe
Vehicle shuts off after remote start
I will need to know the make and model of your car to answear this possitively but this sounds like a problem with your bypass module. That is if your car has a immobility system. an easy way to check this is stick your key in the ignition "Do not turn the key" just insert it in the ignition then hit the remote start. if the car does not shut down that is where your problem lies. if the car still shuts down then your problem is due to either a bad brain or faulty wiring.
Hope that helps,
Nov 25, 2008 | Car XR9000 Two-Way Confirming Remote Start...
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
48 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
