Sony MHCGX355 shelf system stuck in standby mode. System will not come on standby light blinking.
  • finejunk Dec 12, 2008
    my shelf system is RCA-9150 but the solution should be the same since shelf systems are pretty generic
    help
  • solver gariz Feb 01, 2009
    sharp 5 cd changer model#cd_es777, the standby light blinking when press on. shut off itseft standby light after 5 second. i replace back same amp ic #. stk412_420. it work ing same .hpoefully have solution to solve my problem. thanks!
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: why do my sony mhc-gx450 cd shelf system power
This usually indicates faulty wiring, or miswiring. Disconnect the wires, one set and turn the unit off and on to see if that elimates your problem. If it does, the wiring or component is at fault. If you disconnect everything and have the same problem, it's an internal fault with the unit and will have to be troubleshot. Get and estimate first, to evaluate whether or not it's economical to keep, or replace with a new one. Good luck, hope this helps.
Posted on Mar 25, 2010
Sony HCD LX20i audio shelf sysyem won't turn on. Standby light flashing. Disc stuck in it.
Check the speaker wires for shorts, if okay! suspect the audio output ic's, the protection circuit won't come out of standby because there is a short.
May 06, 2012 | Audio Players & Recorders
Sony hcd-gx470 manual
My Sony Mini MHC-GX470 have been working until a power outage yesterday and now it will start coming on the goes back to standby mode. I can hear it going through the system, starts the radio and immediately goes to STANDBY.
I need HELP!!!!!!!!!!!!!!!!!!!!!!!!
Jan 07, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
I have a gpx hm3817dtblk shelf system and i was wondering if you can get the alarm to play a cd instead of the radio or if you can do either one and how? Or does it even have an alarm?
The manual:
http://www.retrevo.com/support/GPX-HM3817DT-manual/id/1183ag710/t/2/
Page 6>>>>
Setting the Clock
a. Press the STANDBY button until the unit is in standby mode.
When the unit is in standby mode, the STANDBY button will be red.
b. Press the CLK ADJ. button. The time will begin to blink.
c. Press the HOUR and MINUTE buttons to adjust the hour and minute.
d. Press the CLK ADJ. button to set the adjusted time.
Setting the Alarm
b. Press the ALARM SET button. The time will begin to blink.
c. Press the FUNCTION button to seleect CD, Radio, AUX, or Buzzer.
For Buzzer mode, the display will not show any indication.
d. Press the HOUR and MINUTE buttons to adjust the hour and minute.
e. Press the ALARM SET button to set the adjusted alarm time.
An alarm clock icon will appear on the LCD Display when the alarm is set.
Jan 03, 2011 | GPX HM3817DTBLK Shelf System
Standby led sony MHC-GNZ888D blinking (intermitent)
power amp.or power supply printed circuit board.
nuwan.
Jan 13, 2009 | Sony MHC-G100 Shelf System
Eternal Standby mode
power amp problem.can you do the electronic repairs?
nuwan.
Dec 18, 2007 | Aiwa NSX-AJ20 CD Shelf System
No powering up
2 blinks is +B OCP protection. The manual states "Short circuit of power supply system in each circuit." and "Goes to the standby mode. Short circuit of +B line"
Dec 10, 2007 | Sony KP-53XBR200 53" Rear Projection...
Stuck minidisc
Turn the power off and back on at the mains. With the machine now in standby, press and hold the "Play Mode" and "Minidisc Play/Pause" buttons together. The machine will enter test mode and the disc should eject. Switch the power on and off again at the mains and the machine should be back to normal.
Oct 16, 2007 | Sony DHC-MD333 Shelf System
Sony MHC-GX9900 Shelf System
i have the same problem with the blinking light this problem is due alot to over heating be careful your fan is not burned up or is not being blocked it is a protect mode activation to prevent overheating
Jul 04, 2007 | Sony MHC-GX9900 Shelf System
201 people viewed this question
 Grubhead
Grubhead
