Question about KitchenAid Dishwashers
Kitchenaid dishwasher won't turn on
The on button seems to be stuck and dishwasher will not turn on when the button is pressed.
    Sergeant:
    Champion:
  • 338 Answers
If this is the model that has the on/off button then the button is probably broken. you should schedule service since there alot of small parts and would be very difficult for someone who has not seen this before to take it apart and put back together.
Posted on Nov 25, 2008
Kitchenaid kudk02crbs2 dishwasher normal button not working
In this situation you must replace the control panel
Dec 02, 2016 | KitchenAid Dishwashers
Resetting computer on kdte204dss0 Kitchenaid
The most common reset for the dishwasher is:
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | KitchenAid Dishwashers
Seems to start and then cancels and drains
The flood switch might be turning on. This is the float unit at the base of the dishwasher. Could be the that the spring is faulty. Press and see if it comes back up. Otherwise there is leak in the dishwasher and water has collected at the base under the switch.
May need the actual model number to provide a more precise solution.
Feb 15, 2014 | KitchenAid Dishwashers
Kitchenaid kudi01ilwh2 won't start
By won't start do you mean that everything is set ok but when you press Start button then nothing happens.
In that case most likely the door is not sitting properly or the door latch or door switch is faulty causing the dishwasher to not start.
However, if nothing happens on the panel when you press buttons but power is there, then most likely the panel is faulty and can be replaced.
you can trace the parts in these diagrams.
Nov 01, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
I can't turn on my KitchenAid Superba dishwasher. I pushed Normal and Start, and the Normal light started flashing, but didn't turn on. Pushed Cancel and now both the Normal and Cancel are...
Did you try turning off the power and then connecting it again?
If still problem is there open the door. Press the following sequence of buttons HI Temp Scrub, Energy Saver Dry,HI Temp Scrub, Energy Saver Dry. Now close the dishwasher door and latch it too and press the cancel button. This must reset the dishwasher.
Aug 13, 2011 | KitchenAid 24 in. KUDU02FR Built-in...
The child lock is stuck on my kitchenaid superba dishwasher
Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Apr 03, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
////////////////////my kitchenaid dishwasher lights are flashing
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Nick,
It sounds like you have tried all the normal things for this. It is possible that you have a stuck key on the panel. Try pressing all the buttons several times to see if they may be stuck. It may just pop it loose. If that does not work you may need to try kicking the breaker off overnight. If that does not work you may need the electronic control. Lots of luck to you. Mike
May 07, 2008 | KitchenAid 24 in. KUDP01DL Built-in...
Kitchenaid dishwasher will not start
sounds like theres something stuck in the drain pump.hope this helps.
Mar 05, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
