Question about Frigidaire ATF6000ES Front Load Washer
Washer wont work
It shows dr on the display
  • ryanrittmill Nov 25, 2008
    code on display is dr and it beeps 4 times
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, as the error code implies, it is a drainage problem. Although a messy job, the repair is actually simple. Access to the bottom drainage system is gained by removing the kickpanel. The corrective procedure would then be to clean the drainage system. For your particular brand, this has been addressed here. An excerpt:
"to begin there are two screws on the front panel on either side a few inches in.. remove these and gently pull the bottom of the front panel towards you, and release the clips for the top. The front panel should drop down. Inside the unit towards the left rear is the pump assembly ( #131724000 ) - it should have a red/white and a black/red wire clip on harness running to it. Remove the hoses and carefully look inside for a small coin or something blocking the impeller on the pump. I've found various small items like hair pins, change, a baby sock, string, chains etc etc blocking the impeller. With any luck, it won't be the pump assembly or control, and is something simple. Give this a shot, and lemme know how it turns out for you. After the initial check if required we can look into some other possibilities."
To give you an idea, an exploded parts diagram maybe found here while parts list may be referenced here.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 25, 2008
    Genius:
  • 1,550 Answers
This error code is displayed if the control failed to save cycle information during a power failure.
Press STOP/CANCEL to clear the display.
  • SAM ANDERSON Nov 25, 2008
    • DR code occurs if the door cannot be unlocked.
    • Door
      Lock Mechanism broken or removed from the Door
    • Check
      Door Lock/Switch Assembly
    • Check
      the wire harness connections to the Door Lock/Switch Assembly
      and Central Control Unit (CCU)
    • Door
      Lock/Switch Assembly Failure
    Genius:
  • 1,847 Answers
That is the errorr code is that full code that is displayed?
  • Legin Varghese
    Legin Varghese Nov 25, 2008
Boss DR-3 Dr. rhythm LED screen lights up by does not show any information. what can I do to fix problem?
take it appart. there is a conductive rubber between lcd pannel and the pcb use widow washer fluid without amonia to clean it
Jul 20, 2016 | Roland Boss Dr. Rhythm DR-3 Drum Machine
DR STAY ON WONT START
Try this and please click helpful.
Do you have any error codes showing up? To find a manual for this unit, google FRIGIDAIRE AFFINITY WASHER REPAIR MANUAL
most of these units have the same parts inside them.
Jan 04, 2015 | Washing Machines
I have a Frigidaire front loader washer model number LTF7000EGO and it was washing fine then started a beeping noise with dr flashing. What does that mean?
Hello friend, thank you for your post!
I understand that your Frigidaire washer, LTF7000EG0, is displaying a "DR" error code. "DR" stands for door which means a problem with your door it could be an issue with the door latch assembly or door strike. I would suggest resetting your washer and you can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes.
If you continue to experience an issue with the error code "DR" I would recommend reaching out to a professional technician for proper diagnosis and repair. I hope this information has been helpful. -Matt
Oct 09, 2014 | Washing Machines
Why is my frigidaire affinity atf600sfo washer displaying a DR when I push start?
Hi adakota5267, thanks for the post!
I understand that your Frigidaire washer, ATF600SF0, is now displaying DR. DR stands for door open or door problems, which could be an issue with your door switch or wiring issue. Sometimes the issue can be resolved by opening and closing your door once more. If the issue continues I would recommend having a technician out to your home to diagnose and repair the washer. -Matt
Jul 25, 2014 | Frigidaire Washing Machines
My washer is messing up it wont finish washing, theres a DR that shows up whats that mean?
it is a code 4rm the washer that simply means error during washing ,troubleshoot panel and if it persist call ur service engineer
Jul 07, 2011 | GE WSM2420D Unitized Spacemaker Washer /...
I have the frigidare affinity front loader washer and just started it up. It stopped about 5 mins into the cycle and the indicator light says dr. I tried to shut the door but that didn't work. So I...
You need to replace the door lock mechansim. Fairly easy to do yourself, just pull the spring strap off the rubber door gasket and remove 2 screws holding door lock. Install new door lock and re-install door gasket and spring strap, and WALLA! she works:)
Nov 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
