Question about GSI Technologies 73365 Vortex Work Top Blender
My crank blender's gears no longer move smoothly!
I have a month-old GSI Vortex (Hand Crank) Blender.
When I crank the blender on the second (faster) speed, it goes a little bit, then stops.
You have to jiggle it to free it, then it goes again and stops again.
Could this mean that the gears inside need lubrication?
Or maybe the gears are loose?
What do I to to fix it?
My man has offered to take it apart to see what the problem is, but he has already destroyed so many things by taking them apart.
lol.
  • Reflection2 Nov 25, 2008
    Ok I just checked out the blender again...
    CORRECTION:
    It's actually the lower speed that has this problem; the higher speed still cranks smoothly.
How can I find a new Bamix old model spice blender/chopper
Bar mix products made millions for world wide sales
kitchen aids that change design so often
they cant support a large parts division
(R&D is geared to sell the next better barmix product )
if you cannot find a new old part
or super ceeded shaft from the next model up
or used drive shaft for sale online
look for a complete used bar mix spice blender/chopper
some people collect barmix units for a hobby or collection
and sell double ups
when you say old model
if the shaft is plastic ....... its .unfix able
its a heat molded construction process
Vintage Bamix M122 2-Speed Hand Held Food Blender Mixer-Chopper
Sep 16, 2016 | Bamix Blenders
The blade barely moves and appears to be stuck with old debris/food. I want to try to take it apart to clear it. i think the switch and motor are ok
I have picked up plenty of these babies at flea markets in the past. Taking it all apart to clean is a last-resort . There are some Youtube guides, though not for exactly the same model, here (
How to open and repair Braun Hand Blender Part1 ,
How to repair Braun Hand Blender Part2 )
Sounds like the motor still moves things a bit, but you're wisely opting to not burn it out. :-)
Before you go that far, there are some intermediate things to consider. First of all, don't do anything with the blender plugged in! It can mess up fingers big time. No cutting corners here!
If the debris is external, soak it in soap and hot water, blade down, for a while, and remove what you can with a soft brush or washcloth, being careful with fingers around the blade. If the blade moves at all, grab, preferably with gloved fingers, or with a pair of pliers, and rotate the blade back and forth. If it goes a little bit and stops, don't force it, just go back the other direction as far as you can go. Hopefully after a few runs through the range of motion, it'll start moving further, and you can loosen it. Feel whether it seems to have friction, some specific spot where it binds, whether the resistance feels friction-y, or gummy. Be patient and see if working it by hand, maybe with help from a tool for grip, will loosen it up.
Also check the cord. If it's been wrapped around and around the blender for storage (no, I've NEVER done that, nope nope), over time it'll tend to get really twisty and prone to tangling on itself. it may also then get partially broken, particularly at the spot where the cord enters the body of the blender. You can carefully try wiggling sections of the cord while it's running. If things suddenly change RPMs a lot, then the cord needs to be replaced (which will lead you back to disassembly)
Trying to lube it is dodgy. This will be going into your food and drinks, and you really don't want it slowly depositing 3-in-1 oil or WD-40 back into your smoothies for the next month. If it comes to that, you'll need to take your original aim and try to disassemble it. Then you can make sure that any lube is only where it belongs.
You can find a bit more of a general discussion on disassembly (not specific to Braun) here (
How to Repair Hand Blenders DoItYourself com ) There is also a general 'Manual' for an MR-30 here (
Braun MR30 Hand Blender ) Which describes cleaning for another of the monolithic models that don't have blade assemblies that detach.
Nov 06, 2015 | Braun Hand Blender Model 4172-b
Teeth sheared off the rubber drive gear on Krups Blender Style 572. Have ordered part and need installation instructions
take a flat head screw drive to the bottom of the blender and us it to hold the blender shaft in place while you turn the gear by hand or with a plyers (it is reverse threaded) and it should spin right off. when you get the new on it should spin right on.
Aug 12, 2011 | Krups 572 Power Xtreme VI Work Top Blender
Braun hand blender shaft coupling has rounded smooth.can i get another? as the motor is still good.
Refer to http://braun.com/ to find the website for your country.
Otherwise, refer to http://braun.com/us/consumer-service.html which will help you locate a local Service Center.
May 13, 2010 | Blenders
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
My Blender knives don't cut good anymore, what should i do?Can they be changed?or should I buy a new one?
Do you mean blender blades?
Either way, your blender blades/knives need to be sharpened.
This is the key to making your blender last a long time.
You may need to reach into the unit to sharpen them if the blade part doesn't twist off.
Good luck :)
Nov 11, 2008 | GSI Technologies 73365 Vortex Work Top...
Intelli blender will not work
Do you hear it hum when you try to turn it on?
If yes, remove the cup. Try again... if the motor runs, try moving the blade by hand. If it is seized, remove it and clean it to free it again.
If not, possibly blown windings on the motor or divider circuit (which supplies different voltages to the motor for the different blend speeds). Repair will be required in either case.
Mar 24, 2008 | Westinghouse WST2000 IntelliBLEND Work Top...
Buttons click but it won't run.
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask, strawsj1234@hotmail.com
Mar 17, 2008 | Black & Decker BL5000 ProBlend Work Top...
GSI Technologies 73365 Vortex Work Top Blender Logo
113 people viewed this question
Top GSI Technologies Blenders Experts
eyecam
Marvin
Marvin
Ross Keen
Are you a GSI Technologies Blender Expert? Answer questions, earn points and help others
