Question about GE Refrigerators
Ice maker only makes crushed ice
I hae a GE Profile side-by side, white on white 21.6 cu ft. refrigerator. Whether it is switched to cubed or crushed ice , it only makes crushed ice
  • 1,543 Answers
Pull the ice bucket out. Behind it you will see a rectangular hole with a rod in it. The rod should be able to move with your one finger up and down. If it does not, the solonoid attached to it is either frozen or burnt out.
Posted on Nov 25, 2008
Ice maker only delivers crushed...cube option not working
The control board is probably bad. Replacing it might fix the problem.
Dec 31, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Our ice maker is making 5-10 cubes per day. Ice
OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
Apr 14, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
GE GSH25KGMD Crushed Ice Only
Remove the ice bin . Set the dispensor for cube and push in the door switch . Press the dispensor pad and you should hear a loud bang . If your looking inside at the same time , you should see a square white "gate" lift . This gate lifts to lift the rod on the ice bucket to give cubed ice . If this gate does not lift , then the auger solenoid is probably bad . Part # WR62X58
http://www.apdepot.com/Buy/IPLFrame.asp?Brand=GE&ModelNo=GSH25KGMDWW&IMGFile=LD1IEWSN&IMGID=uZmA
Aug 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker will not eject ice cubes in GE Profile gss25tswass
Empty all ice from the bin and from the "Drill" like Ice shaper spinning unit. Let the unit make some new ice and see if that works.
Feb 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker
There is a cheap repair manual for this model listed on eBay. The item number is 200262539606.
Premmy
Oct 04, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
444 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
