Question about Kitchen Ranges
My meat probe on my jenn-air electric stove works but no beep
When using the meat probe there is no beep at end of cycle it just turns off. The whole circuit board has been replaced and still it doesn't beep
    Sergeant:
    Champion:
  • 338 Answers
You may need to scroll through your settings to turn the beep on
Posted on Nov 25, 2008
We have an electric jenn air stove,Has 2 coil burners on left, two flat on right, with a vent in middle.The oven istaking a long time to heat up and to cook. Now the bottom coil will not shut off.
Unplug the stove from the outlet or turn off the circuit breaker to the stove at the service panel.
Remove the elements (coils) in question; (The coil elements pull out of their socket connections) Do they show any visible signs of blistering or breakage? Replace them.
No visible signs of damage, use either an analog or digital multimeter to perform a continuity test.
A continuity test will determine if a continuous electric path is present in the element or not. If continuity is present, the coil is okay. If there is no continuity, the electrical path has been broken and the coil will have to be replaced.
Set your meter dial to the Ohms scale, lowest setting.
If using an analog meter, you'll first have to calibrate the meter by touching the tester's probes together and adjust the needle to zero.
(You don't have to calibrate a digital multimeter the same way you would an analog meter, for obvious reasons)
Proceed with the test by placing one of the meter's probes on one end of the coil element's terminal and the other meter probe on the other terminal end of the coil. If you get a reading of 0-50 Ohms of resistance, the coil is okay.
If there is no needle movement on the analog meter or no change in the digital read out, the coil is burned out and will need to be replaced.
Mar 01, 2015 | Jenn Air Kitchen Ranges
F3E3 Meat probe Shorted
faulty meat probe, probably a factory defect, if still covered by warranty, return oven for replacement.
Mar 22, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
Funny - didn't ask about a slide in electric kitchen range - was asking about my Jenn Air Stove. You deal with them, correct? Have a Jenn Air WW2780B that I can't seem to get working. It started...
I had a customer with the same problem last month and I believe it was on the same model as yours. Let me look in my database and I will get right back to you.
Warmest regards,Richard
Nov 01, 2011 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Front control panel shows "Remove Probe From Oven" & Beeps.
I have the issue as well, seems like when I use the convect. feature. I have not called to have it serviced yet, but I have found that opening the oven door and truning the fan on for a few minutes, corrects it. At least until you turn it off again.
Sep 23, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Kichenaid electric stove
the probe is put into the oven to sense heat and to prevent the oven from oveheating during normal operation. the reason the probe is beeping is because it's dislogged or needs to be replaced.
the only way to make the beeping stop is to disable it but i wouldn't recommend it.
have a technician run a diagnostic on the stove. sounds like the probe needs to be replaced.
Jul 09, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air Gas Range
F1 is a bad power relay board.
F8 is a shorted meat probe alarm (probe jack or the harness to the probe jack)
Dec 19, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air stove locked
Check the trouble shooting section of your owner's manual for your various fault codes. It may point you in the right direction as to your next course of action.
Oct 04, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Stove controls beeping and flashing "Probe"
Most likely oven sensor / probe is the problem. It can be tested with an ohm meter. Not sure about your model, but most should read around 1100 ohms at room temperature. If there's a tech sheet somewhere on your unit, it should tell you.
Sep 23, 2017 | Jenn-Air SCE30600 Slide-In Electric...
Kitchen Ranges Logo
239 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
