Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
There is a small window in the right top corner with the number 2
In the right top corner and i cant grt it to go away
  • 3 Answers
Hit the PIP button on your remote, it will cycle through a couple of other PIP each time you hit it until you finally get back to normal.
Posted on Nov 25, 2008
Power LED and other connection diagram for MSI 7142 motherboard
MSI Support > K8MM-V motherboard (ms-7142) > Main Support page,
http://www.msi.com/product/mb/K8MM-V.html
Hover your mouse cursor on the Download tab.
(Overview / Specifications / Download / Support / etc)
In the drop down list click on - Manual
Underneath the Download subheading click on the blue -
M7142v.1.0.zip (2005-09-07)
Click on the 'country' name nearest yours.
(U.S. is a country. Europe and Asia are continents)
A small window will come up -
Opening M7142v1.0.zip
Make SURE the small circle to the left of Save File, has a Green dot in it.
IF not; click in the small empty circle to the left of Save File.
Now go below in the small window, and click on - OK.
A small download window will come up.
Allow the file to fully download, then DOUBLE-click right on the file name. ( M7142v1.0.zip)
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name.
(Next to the red Adobe PDF icon)
There is the motherboard manual in PDF file form.
The Adobe Reader page number box is at the Top, to the right of the Down Arrow.
You can go page by page, to the page you want, using the Down Arrow; or if you know the page you want you can do this,
1) Put your mouse cursor in the page number box at top.
Left-click once. Anything in the page number box, is now highlighted in blue.
2) Type the page number.
3) Press the Enter key.
A) Go to Page 5 - Layout.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
On your motherboard there are two.
JFP1 and JFP2.
Junction Front Panel 1 and Junction Front Panel 2.
JFP1 is on the Right side of the motherboard, down in the Bottom/Right corner.
It sits Vertically on the motherboard.
Two columns of contact pins.
5 on the Left side, 4 on the Right side.
Go to Page 14 - Front Panel Connectors: JFP1/JFP2
The pins on the Left side are numbered ODD.
The pins on the Right side are numbered EVEN.
Starting on the Top/Left side, coming down;
Pins 1, 3, 5, 7 and 9.
Starting on the Top/Right side coming down;
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
This is reserved for the factory. Believe it is a 5 Volt (DC) test point.
D) Pins 2 and 4 are for the Power On LED light.
It is for a TWO wire Power On LED light.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10.
The JFP2 header is to the Left of JFP1.
It is situated Horizontally, and close to the bottom of the motherboard.
Two rows of pins.
3 pins on the Top row, 4 pins on the Bottom row.
The Top row is numbered ODD.
The Bottom row is numbered EVEN.
Starting on the Right side, going towards the Left; Top row,
Pins 1, 3, and 5. There is NO Pin 7.
Starting on the Right side, going towards the Left; Bottom row,
A) Pins 1, 3, and 5 are for a THREE wire Power On LED light.
I assume Pin 1 is for the Negative wire ( - ), and Pins 2 and 3 are for the two Positive wires.
It's for a dual color Power On LED light.
Example: Turbo Mode has a Green light, Normal Mode has a Yellow light.
B) Pins 2, 4, 6, and 8 are for an internal speaker.
Internal speaker is used to hear the BIOS Beep Codes.
For additional questions please post in a Comment.
[Thought you may want the motherboard manual, too]
Regards,
joecoolvette
Mar 04, 2013 | MSI K8MM-V Motherboard
Find mobo speaker connector
Front or Rear connections? Open the case, it's at the rear of the Mobo. It will be enclosed in the connectors. If you have lost a channel, it may not be easy to repair. A sound card is a option.
Jan 31, 2013 | E-Machines T3092 PC Desktop
Location of the usb pins on the mainboard
http://www.matsonic.com/Computer-Desktop-Support/Models/ms9307c%2Bseries.php
Go to the small list on the left side, under the bold black subheading - Matsonic Motherboard Manuals (PDF)
Left-click on - MS9307C
When the small window comes up on the right, make SURE there is a Green dot, in the small circle to the left of - Save File.
IF not left-click in the small empty circle to the left of Save File.
Now go below, and click on OK.
A small window will come up on the left. Allow the file to fully download. Then DOUBLE-click right on the file name.
Go to the far left side, and click on Extract all files.
Then click on Next, Next, and Finish, at the bottom of the next three small windows.
In the last small window DOUBLE-click right on the file name, next to the red Adobe PDF icon.
There is the motherboard manual.
Go to Page 14 of the Adobe Reader page number. (Top header)
Actual manual page number is 10.
Motherboard installed in computer case, USB1 header is at the bottom right corner. It lays Parallel to the bottom of the motherboard.
5 pins across the Top row, 4 pins across the Bottom row.
USB2 header is right above the top white PCI slot. (PCI 1 slot)
5 pins across the Top row, 4 pins across the bottom row.
Pinout for the USB headers is on Page 22 of the Adobe Reader page number. Page 18 for the actual manual page.
Regards,
joecoolvette
http://pinouts.ru/Slots/USB_pinout.shtml
Oct 23, 2012 | Matsonic MS9307C+ (810884003185)...
I need help asap on replacing wires on distributor cap, i understand the firing order but i cant figure out where 1 is on cap. is it next to the stick out part.
Im sure youve figured this out, but just in case!
Find the connector that plugs into the distributor.
Follow the rectangular shaped top part on the distributor
to the opposite side away from the connector.
Number 1 wire is at the right corner of the rectangular
top part when youre standing at the front left corner
of the car by the battery and looking along that rectangle on top.
Its right against the thumbscrew that tightens down the air
filter housing.
number 8 is the next one to the left of number 1.
can post a pic if you need.
Jul 11, 2011 | 1988 Cadillac Sedan DeVille
Numbers 1 2 3 appear on screen and small + in box in right hand corner cant see what they are for or how to get rid of them
Just draw your finger from left to right across the centre of the screen and you should be back to normal. Don't know what the numbered boxes are though.
Jan 24, 2010 | LG GT505 Cell Phone
SEVEN SQUARES ON A PIN BOARD I CANT GET IT
Hi there,here is you answer,enjoy
There are 6 lines of pins
On each line they are in different positions
So for this occasion we are gonna number these from 1-28,from left to right then from top to bottom
We will give each square a colour and a number
1*Large blue square join the 4 corners at pins 8 to 16 to 23 to 28
2*Large yellow square join at pins 4 to 12 to 21 to 27
3*Small red square join at pins 17 to 22 to 24 to 26
4*Small brown square join at pins 14 to 18 to 20 to 25
5*Small light blue square join at pins 5 to 9 to 11 to 15
6*Small white square join at pins 1 to 2 to 6 to 7
7*Medium white square join at pins 3 to 10 to 13 to 18
Hope this helps its the easiest way i think i can describe it
JonnieC
Jan 06, 2010 | Nintendo Professor Layton & the Curious...
Number 2 In top right hand corner
Menu....display ...off
this should do it
Dec 13, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Number 2 in top left hand corner
hold down hash key for 3 seconds and it will go away
it is something to do with which line you are using,
Sep 24, 2008 | Nokia 6230
Removing interior door trim '93 suzuki swift
Assume you have been able to remove window winder.
The surround of the the door handle (interior) is clip on at four points. Tabs are about an inch in from each corner and slide over a plastic nub to lock in place. . Start at top right corner. Get a small flat blade screwdriver with blade horizontal and gently - repeat gently, prise tab upwards while applying gentle pressure away from door and pushing slightly upwards. Tab should just slide off nub holing it in place. Do same for other side on top tab. Gently wriggle downwards so bottom tabs disengage. Installation is reverse.
Sep 14, 2008 | 1993 Suzuki Swift
Yahoo Messenger
1- click on top of the window on the title bar, while holding your left mouse button...move the window to the left until you see the right bottom corner about 1 inch from the right corner.
2 - click on the right bottom corner to resize the window and drag it all the way to the left about an inch away from the edge.
3-repeat step 1 until the window is back to normal size
Feb 24, 2008 | Computers & Internet
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
