Question about Sharp Televison & Video
Given Sharp SX68C7 TV - no manual. Don't know how to tune
Don't know how to tune in stations as TV is tuned to different area. Can you tell me how to tune stations?
  • thelassigs Nov 25, 2008
    Model no. is definitely SX68C7 on plate on back of TV. It was purchased 1995 in Australia.
  • thelassigs Nov 27, 2008
    RE previous advice: remote control does not have button called "set". Most buttons have picture symbols on them! Remotew turns set on/off, and changes channels, but channels are not locally tuned.
    Scholar:
  • 174 Answers
Turn on your TV.
On your Tune In remote, press TV and release.
Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
Enter the first three-digit TV code for your Sharp from the list which follows:
093, 165, 039
These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
::Now Test Your TV::
Why test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
Posted on Nov 27, 2008
    Genius:
  • 2,035 Answers
Press the PRESET button
on the W set twice.
Press the CHANNEL UP
(d)or CHANNEL DOWN
(~) buflon on the TV set or
the remote control to
choose the channel position
to be set.
The illustration on the left
shows that channel 5 has
been selected to be set.
When you press the
VOLUME DOWN (~) or
VOLUME UP (<) button on
the TV set to locate the
channel you want to preset
to the position. Search is
initiated and when a TV
signal is received during
the search, the search
stops.
Repeat steps 2 to 3 above
to set channel position for
other broadcast, cable
channels, etc.
After the above operation,
press the PRESET button on
the TV set again.
The IV set returns to normal
mode and the channel
number last preset is
displayed on the upper right
corner.
NOTE:If you use Manual Channel
Preset in a weak reception area,or
under bad reception conditions,
you might not pick up the
broadcast you expect.Instead you
might skip to another broadcast.If
this happens, when the picture
appears on the screen, press the
VOLUME UP (<)or DOWN(~)
button to force the Manual Search
to stop, then press the PRESET
button and adjust the picture using
fine tuning.....
Good luck....
Posted on Nov 25, 2008
  • 6,487 Answers
Check this link for the user manual of this unit http://support.sharp.net.au/
    Brigadier General:
  • 3,614 Answers
  1. Turn on your TV.
  2. On your Tune In remote, press TV and release.
  3. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  4. Enter the first three-digit TV code for your Sharp from the list which follows:
    093, 165, 039
  5. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
  • Sharp Master
  • 19,396 Answers
Here is sharp download, but there is not the model, double check the model you gave me.
Does tuning stations in a dvd/vhs change the tv settings?
no, it will not change your tv settings. because your only tuning the stations of your lgv271. so don't hesitate on tuning your lg v271.
if you have any questions, just ask me.
Jan 14, 2012 | LG V271 DVD Player/VCR
Mikomi lcd/dvd icannot program the tv to any stations
Have the same problum they say my signal board went bad and I cant find a part to get it fix the com. went bankrupt.
Sep 15, 2009 | RCA Mikomi 5290925 15 in. LCD TV
I inherited an old Sony Trinatron TV it's working fine & have just bought and LG VCR to replace a VCR that broke which also works fine. The problem is in tuning the VCR into TV. I automatically tuned...
Depending on where you live you might have to go buy an HD antenna and scan for channels and hope you can get a PBS station or something to get you off of zero and then go into the menu and manually program a channel you can use to tune your VCR maybe that might do the trick
Jun 22, 2017 | Televison & Video
Tuning in a N-4858 nec tv
I have also recently been given a 10 year old nec n4858 tv and would like to know how to tune in the stations?
Jun 15, 2009 | Televison & Video
Tuning 5 uk channels
Judit
It depends what make of TV you have, basically you need to auto tune it to get the stations back. You need to select your MENU, then TUNING, then AUTO TUNE wait until it tells you completed, then STORE.
This should Fixya!
Please remember to rate this solution .
Oct 23, 2008 | Televison & Video
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Feb 22, 2008 | Audio Players & Recorders
Cant tune my Hitachi TV
please check web site for any thing in remote. www.remotes.com and give model name in search. hopr this will help. good luck.
Sep 30, 2007 | Televison & Video
Mitsubishi TV model CY2525
as tv is old please replace it by new kit or whole pcb. now a days you get new pcb(CHINA MADE) at cheap rate with remote & mo of channals more.
Sep 26, 2007 | Televison & Video
Televison & Video Logo
118 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
