Question about Brother Office Equipment & Supplies
Hi - I have a Brother printer/fax/photocopier/scanner MFC - purchased about 3 years ago. I can't lift it to find a serial number because my right arm is sprained. But I can tell you it uses "LC 31 C" printer fluid replacement cartridges. Last week is began refusing to print and the message I get is: UNPLUG PRINTER, CALL BROTHER, ERROR 41. I've been successful several times unplugging it, then resuming my printing jobs, but after two times of doing that, it stops again and flashes the same message. Please tell me if there is a quick fix. I'd like to get a new one but commission sales job isn't paying these days! HELP! Thanks for your time and energy. Look forward to hearing back as soon as you can. THANKS! Robin
No, I didn't fix it. It says "Error 41. Unplug machine and call Brother." I figure it means it's crapped out. I don't wanna pay to have somebody tell me I need a new one?! Brother oughta be offering Error advice for free to bring folks back as repeat customers. If you have any free advice - it'll earn a future customer! Thanks for your time. Robin
Posted on Nov 25, 2008
My mfc 6490cw sends blank faxes
Normally this is caused by not loading the item being faxed in the ADF (Auto Document Feeder) correctly. Try sending a Fax of only one page by putting the page Face down on the Scanner plate (Lift the top of the printer to access the scanner plate). if this works then check the ADF scanner plate is not obscured.
Oct 20, 2014 | Brother MFC-6490CW Inkjet All-in-One...
My Brother MFC490CW Fax M/c will only send one fax then reverts to scanner
A DEPENDABLE MACHINE BUT LACKS PRINTING QUALITY! Date of Review: Jan 14, 2009. The Bottom Line: Love the fax...not too impressed with printing quality or ink prices. Review: I bought my Brother Multi-Function Center 440CN a couple of years ago. .... Brother MFC-490cw Color... Brother MFC-440CN All-In-One. ...
www.shopping.com
Dec 03, 2009 | Office Equipment & Supplies
We just purchased the Brother MFC 7345N. We love it. But we may not have done everything right at the time of installing because we can't get the scanner to work. Any suggestions ?
If you are using the scanner to send a fax, you may have to set th date, time and other settings to enable the scanner to operate when faxing out. Please read the following from the service manual of this machine:
The Telephone Consumer Protection Act of
1991 makes it unlawful for any person to
use a computer or electronic device to send
any message via a telephone fax machine
unless such messages clearly contain, in a
margin at the top or bottom of each
transmitted page, or on the first page of the
transmission, the date and time it is sent
and an identification of the business or
other entity or other individual sending the
message and the telephone number of the
sending machine or such business, other
entity or individual.
Oct 17, 2009 | Brother MFC-9420CN All-In-One Laser...
"unable to clean"
Hi dbostrander.
First check for foreign objects in the paper path. Check if you have any faxes in memory because you will lose them when removing power; see later.
Pull out the paper tray from the front and check for paper jams or torn paper anywhere inside the machine. Also check the 'jam clear screen' at the back of the printer. Remove the cover, remove any obstacle then replace ther cover.From the front of the machine lift the top cover from the right side till it is fully open on the slide. Check for jams. If the jam is under the print head you will have to disconnect the power (losing any faxes in memory *see below) to move the print head out of the way to clear the jam.Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
Check whether the MFC has faxes in
memory
1.Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
and then reconnect it then do as above.
—OR—
If faxes are present, you can transfer them to
another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3.Enter the fax number to which faxes will be
forwarded.
4.Press Mono Start.
5.After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,0, 2 in step 1.
Hope this helps,
Mark.
Mar 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
How do I change my fax number?
I found you manual to download right HERE:
- as I´m informed, you don’t need to change you FAX number, as your fax machine will receive any call on the number you connect the machine to.
5757e4d.pngdo vote, if this helped you.
regards
/Teis
Jan 16, 2009 | Brother Multi-Function Center MFC-240C...
Vertical lines on photocopies/faxes
The MFC-7420 Manual recommends cleaning the scanner glass and white plastic bar above it with isopropyl alcohol. Page 11-22 has a diagram.
I am having a similar problem but cleaning it did not work. But try that first.
Oct 15, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-210c printer
Check the basic settings for your printer to see if they offer 'manual' pickup of the line instead of only the number of rings. I've had the same problem years ago and had to set the fax machine for 6 rings, answering machine for 4 to allow me time to pick up the phone in case I was present. You should be able to find complementary settings with your two devices.
Sep 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
Scanner locked
okay, im assuming the brother all in one in the picture is what you're on about...right?!? anywayz :) basically i think it is because you have got "faxes saved in the memory" it sounds weird but the scanner locked is coming up because the scanner is not going back to its home position. if there are faxes in its memory, it means that the memory has not been cleared. to check press menu/set 9,0,1 - if the screen says "No data" means that the memory has been cleared and i don't know what to do!! if it says "Enter fax.no" means that there are faxes in the memory, in this case, the fax must be cleared of memory, (if you need the faxes, you must save them before proceeding) turning it off clears memory apparently but im assuming you've tried that countless times.Turn off the machine's power switch and then on again. If the error message continues, leave the machine for several minutes and try it again. the MFC-7820 can store memory for up to 4 days, so watch out if you have a 7820. apparently this will resolve the issue and the message should go away, hence the scanner returning to its home position!! hope this helps
user guide : http://www.topedge.ro/info/USER-GUIDE/BROTHER/MFC-7820N.pdf
11-3 is the scanner locked section
11-5 is the fax removal section
Dec 05, 2007 | Brother MFC 7420 All-In-One Laser Printer
USB CABLE FOR MFC 1770
This unit cannot be used as a printer unless you purchase a separate special interface This is from the Brother manual for your product. This was written some time ago and I'm not sure that it is still available. I did a search on Brother and found that they still offer it. Whether it still in stock or not I don't know. Their price is $99.00. Add to this the price of the thermal ribbons and it does not make a very efficient printer. You can purchase the optional Multi-Function Link® package (also called ?Missing Link?). Multi-Function Link® turns your fax machine into a multi-function center, by enabling you to use your fax machine as a printer and a scanner and to use it to fax messages from Windows® applications in your computer. The Multi-Function Link® option is for Windows® 3.1x and Windows® 95/98. Multi-Function Link® is available at most Brother retailers. If you cannot find it, you can order Multi-Function Link® directly from Brother. The item number is PCI-1. Wish I had better new for you. Ed
Jun 13, 2007 | Brother MFC 1770 All-In-One Thermal...
89 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
