Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Keypad does not work when I just change a new battery, no light
I just change a new battery on keypad which mounted outside of garage. when I put password on it, no light and nothing happen.
  • 504 Answers
Make sure the battery is good. anytime you change the battery you need to reprogram the keypad.
Press and release the square button on the circuit board. You then have 20 seconds to input the desired code and press enter.
Hope this helps
Posted on Oct 04, 2010
  • Myriam Tueni
    Myriam Tueni Dec 11, 2014
    Can u please tell me how you changed the battery on the keypad ? I cannot open the keypad in order to change the battery :( thanks
Why won't the keypad outside mount not open the garage door but the remotes work fine.
U will have to re program the keypad follow the directions on the lid of the keypad now on some models u have to hold down * # at the same time until it stops blinking then enter your 4 digit code press enter hold for 2 sec if opener does not release and press again as soon as u hear the opener click or light blink press 0 to store code then wait 60sec and try
Sep 02, 2014 | Chamberlain 1/2-HP Whisper Drive Belt...
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: outside keypad will not open garage door at all bu...
The inside button is hard wired. The keypad is a small radio transmitter. If the battery in the keypad is good and it doesn't work when you put in the code it has probably just quit.
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Outside keypad will not open or close door,but the control inside works. put new battery in no help
The wall control is hard wired to the opener and doesn't use the receiver. The keypad does use the receiver. If you have hand remotes that work then it is your keypad that has quit working. Without remotes you cannot know if it is the keypad or the receiver.
Mar 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Mounted keypad will not open garage door when I enter the code
Make sure the battery is good. It isn't uncommon to get one that has been on the shelf for a long period. If you still have the same problem and your hand remotes work okay you keypad is bad.
Mar 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Keypad and remote will not open door
Did the remote and keypad work before you changed the battery? Changing the battery in the keypad should not affect the remote.
Jun 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad Chaimberlain 32B2171-1 does not work any more
You can try programming but if it still doesn't work then your keypad is just bad. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in your 4 digit code and press enter.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
242 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
