Question about JVC AV-32260 32" TV
Remove CC Black Box without original remote?
Hey guys. I've seen the solution to the closed caption black box that doesn't dissappear. Problem is, I don't have the original remote and have to use the menu options on the front of the tv. I've tried and tried, but cannot seem to find a way to turn off the closed caption box. Any ideas? I have JVC Model No. AV 32050 Manufactured in 1999. I have a Black Block that occupies the screen 2 seconds after I go to a new channel. Everything is find except you cannot see the screen. I do have the original remote. However,  I cannot figure out what to do! Any ideas? Please help. Thank you.
  • Anonymous Apr 02, 2009
    I have this same problem how do I get rid of it??
  • 23 Answers
Try holding the TV button and ok/sel for 30 seconds then manually turn the TV off. Try this a cpl. times. It worked for me.
Posted on May 24, 2009
  • 89 Answers
Hello, I was the one who assisted you in Live Chat, Just wanted to remind you to rate the chat session, Thanks. Have a great day!
Posted on Nov 25, 2008
WE HAVE A BLACK BOX IN THE MIDDLE OF OUR TV AND CAN'T GET IT OFF WITH THE REMOTE
Black boxes in the middle of the screen are text boxes. Text is a part of the closed captioning feature either on your television or your cable/set top box. You would press the closed captioning button on the remote repeatedly until it displays cc off or something similar. Captioning might also be active on your cable box/set top box. There is normally a hidden menu on the cable box and that is where closed captioning is. You have to turn the cable box off. Yes I did say turn the cable box off. Then press the menu button on it and then the hidden menu will pop up. Then navigate to closed captioning and choose disable.
Nov 09, 2010 | JVC Televison & Video
On my TV certain shows (Craig Furgerson, Oprah, The View)on different networks,a black rectangle, about 1/3 of the picture, appears. I cannot remove it.
That box appears to be from the close caption feautre. If you have the original remote you can disable using the menu and go to audio functions and look for close caption to turn it OFF.
Do you have the user's guide for this TV?
If you do not, could you provide the model number of your TV?
Jul 24, 2008 | Sharp Televison & Video
Tip
Black Box on my television.
I have heard complaints from some of my customers, “There is a black box on my television, but I can still see the picture around the edges”. This happens to all of us and is a common symptom and can be fixed very easily. If you have a black box in the picture, on the older sets they would be perfectly centered on the screen, but, on some of the newer sets the black box can be in different places and can be different sizes on different sets.
Most likely the Text mode is on in the Closed Caption menu.
The way you can test if it is in Closed Caption Text mode, when you change the channels, the black box will not appear right away but it will take some time to show back up. This is a very good indication that the Closed Caption “Text” mode is turned on for your television. It just needs to be turned off.
To turn off the closed caption go into your menu and turn off closed caption (CC). This will vary from manufacture to manufacture; it should be in the options menu.
I have seen on some sets like Mitsubishi puts it under the Video adjustments button. So you may have to look around for it.
You may even have a CC button on your remote, which will make it much easier. Just press the CC button until the display indicates that CC it is off.
I hope that this tip helps you and that you enjoy your televisions for years to come.
Thanks for using FixYa
asnowman
on Jan 30, 2010 | Televison & Video
Dark shaded square area in center of tv picture - how do I get rid of it? I am at mothers and she has what looks like a 36 inch tabletop JVC tube tv probably about 10 plus years old. not able to remove tv...
I have heard complaints from some of my customers, “There is a black/gray box on my television, but I can still see the picture around the edges”. This happens to all of us and is a common symptom and can be fixed very easily. If you have a black/grey box in the picture, on the older sets they would be perfectly centered on the screen, but, on some of the newer sets the black/grey box can be in different places and can be different sizes on different sets.
The way you can test if it is in Closed Caption Text mode, when you change the channels, the black/ gray box will not appear right away but it will take some time to show back up. This is a very good indication that the Closed Caption “Text” mode is turned on for your television. It just needs to be turned off.
asnowman
Apr 19, 2010 | Televison & Video
Black box appears on every channel
Hi:
This black box is the close caption box, you must of turned the feature on. Go into you menu setup screen and under CC option turn off Close Captoin, or you may have a CC button on your remote that you hit by mistake, try hitting this button until it says Close Caption off.
Dec 24, 2009 | JVC AV-32D305 32" TV
It can be done with the front panel buttons. Here's a link to the user manual from JVC's site. It's covered in the book.
http://resources.jvc.com/Resources/00/00/99/LCT0305-001B-A.pdf
Sep 24, 2008 | JVC AV-20220 TV
Big Black box covers screen
On the remote control is a button called closed caption or CC.. Someone turned on the closed caption. Simply turn off the closed caption. That black box is called the text box. Good Luck
Apr 12, 2008 | Philips Magnavox 27MS343S 27" TV
Jvc flat screen television model AV32F713 Black box on screen.
On the reomte control (bottom) left of the sleep button is a cc button, push that until "OFF" appears on the screen. The close caption box should disappear. It worked for me, finally.
Nov 29, 2007 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Mitsubishi CS- 27303 closed caption won't turn off
the closed caption is not in the menu, it is in the video adjustments color,bright,sharp,ect. get to those adjustments and scroll until you see C.C. turn it off. i had the same problem but my whole screen was a black box,bought a new tv and everything. just figured it out today
Sep 26, 2007 | Televison & Video
JVC AV-32260 32" TV Logo
313 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
