Question about Tappan TGF320 Gas Kitchen Range
Tappan gas oven
Have a tappan gas stove when the oven is on there is a heavy gas oder. when the oven is off no odor.any help would appricated thank you
  • pblaze Nov 06, 2007
    Mine does the same thing and its NOT from the little bit of gas expelled before ignition. It is a HEAVY gas smell and the oven never gets as hot as its supposed to.
  • Anonymous Nov 08, 2007
    I have this same problem! I see a trend!
  • 183 Answers
This is usually caused by the volume of gas expelled during the lighting process, ie bofore the flame has established, it should be nothing to worry about but check it ignights quickly to resolve problem. Regards Engineer
Posted on Jul 28, 2007
Recently when turning on my stove, I have smelled gas, however upon inspection it is not the gas line, I spilled some Juice while baking a turkey at thanksaches temp. gas odor s eliminated.I want to self...
Hi Bunny.
Now, about your oven.
If you spilled some juice into the oven on Thanksgiving. It will be dried up by now. However the lower burner in your oven should have a shield over it so that juice doesn't get onto the burner.
If the oven is now working properly in bake mode, then the same burner will work in self-cleaning as well. Whenever you turn on a gas appliance you will smell an an oder for just a moment.
Here is the reason. Gas is odorless naturally. The gas company intentionally puts what is called an "ODORANT" into the gas so that anyone can smell a leak. Sometimes, they put too much oderant in and they get quite a few phone calls about leaks. Of course, when there is a real leak, they can also find out about it and take care of before there is any danger.
Your caution in not listening to your son's advice is wise. "Just do it" applies to Nike shoes, and sports. When it comes to safety with regard to natural gas, electricity, or any fuel (like gasoline) "Just do it" can be just fatal. Remind your son of that.
I hope I've helped you. If you have any more questions of me, you are very welcome to contact me through this site.
Best Regards,
Mark
Jan 21, 2011 | Maytag CWG3100A Gas Single Oven
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
TAPPAN MODEL 3 TGF367CFSA, GETTING A F3 CODE, OVEN DOES NOT WORK
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
Feb 07, 2010 | Tappan TGF364AS Gas Kitchen Range
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Sep 07, 2009 | Tappan TGF363 Gas Kitchen Range
Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Jun 27, 2009 | Tappan TGF657 Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
105 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
