Question about Gateway Sb-4100-A PC Desktop
Gateway e-4100 thermal event
Shut down due to thermal event. replaced fan and added new thermal paste. no luck. any thoughts?
  • 4 Answers
There can also be thermal sensors in your power supply, on your motherboard, and video card. Does your problem happen during gaming/heavy computing, after x amount of time, or totally randomly?
If your case conforms to the later ATX spec or some derivative thereof, don't block the hole in the side of the case.
Just some stuff I've run into, maybe you already know this!
Posted on Nov 25, 2008
Gateway intermittent shutdown
I installed a new alternater th battery is new
Dec 27, 2013 | Gateway MD2614u Notebook
Thermal event won't ever allow computer to boot at all
"Computer unplugged from power, press the Power On button in, and hold it in. Hold it in for a count of 10 seconds. let go. Do this procedure two more times. (If the Power On LED lights up, do it again) What you are doing is clearing CMOS Error Codes. Check the Processor fan, check the Thermal Paste. Cheap as Thermal Paste is, and what it does for a job, best advice is to simply replace it. Need guidance post back in a Comment. Before beginning make sure the computer is unplugged from power, and you are FOLLOWING Anti-Static Precautions. Regards, joecoolvette"
Brian Packard;
"I cleared CMOS a few times (has jumper on board too) and even put new thermal grese on it....what finally did it was taking out the CMOS battery. As long as it's outl it works just fine, putting it back in causes an error again. Thank you all for your time however and I hope this post can help somebody else too."
Aug 20, 2012 | Gateway 507GR PC Desktop
Gateway DX4822-01 desktop computer crashes but powers back up after a cool down period. I thought it was a mother board issue and replace the mother board but the same thing is occuring with the new
It is most likely the cpu fan, check to see if you have enough thermal paste on cpu, if not apply a little more and see if that resolve the issue.
Mar 26, 2012 | Gateway Computers & Internet
PC CONSTANTLY SHUTS DOWN DUE TO THERMAL OVERHEATING....PC IS A GATEWAY MODEL MFATXHRN MDW 810
plz mr be sur that the proccesor fan is working good not slow and the seconed part for this problem is power supply try another one good luck dear
Mar 26, 2011 | Gateway Computers & Internet
Keep getting a message that says cpu shut down due to thermal event and when i reboot i hear 3 beeps
If you are looking at the pc from the front, take the left side cover off and ensure that the fan on the cpu is spinning when you turn the machine on. If it isn't, that needs to be replaced. If it is working, shut the pc completely down. Grasp the fan and heat sink unit and ensure that it does not move or wiggle at all. If it's loose, tighten the screws holding the fan/heatsink unit down. Try that and reply back with your findings.
Good Luck,
DP
Aug 18, 2010 | E-Machines eMachines Desktop PC
My Gateway computer shuts down ramdomly. This
Listen for fans coming on, as this sounds like overheating issue. If fans kick in and then stay constant or dont work at all.
The link is for Notebook hardware control, this will monitor the temp among other things (only reference as a guide any software can give you an indication but not exact temp) Generally if a laptop hits 90c it will auto cutout to stop major hardware failure normal running temp (40-55c upwards depending on use) http://www.pbus-167.com/
If the machine is overheating it could be due to blocked vents, faulty heatsink, fans not working or incorrect fitting and thermal paste.
In all honesty if this is due to overheat problems, as the machine has been cutting out my strong advice would be to do all the above ESPECIALLY re-apply thermal paste (arctic silver5) to cpu, it takes about 100-200 hours of use to start to work 100%.
hope this helps, let me know if i can be of further help
Nov 06, 2009 | Gateway T1623BU 14.1" Notebook PC PC...
Computor shuts down. screen goes to black. turn back on and get siren sound and screen says shut down due to thermal event. hit F4 to resume. had same problem a couple years ago and they replaced fan
try applying new cooling pest between cpu heatsink and cpu. Heat from cpu surface should be quickly transferred to heat sink. Either coolent problem or heatsink doesnot properly fit on cpu. But be carefull, you need an 'EXPERT' to do this, or you end up damaging everything.
Jul 30, 2009 | Computers & Internet
Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Jul 28, 2008 | Gateway 7405GX Notebook
My comuter won't start up properly. It stays blank right before the log in screen at start up. It shuts down automatically when I play certain video games.
Ok this could be a CPU Issue, after a while the thermo paste on the heatsink which is on the CPU under the fan the paste will dry out and when it does the cpu once starts working under load due to the games being played will shut down to protect itself and the board.
What you need to do or get someone to do it for you take out the Heatsink reapply thermo paste on top of the CPU (by the way thats what I call it) may be known in your region as Thermal grease (also called thermal compound, heat paste, heat transfer compound, thermal paste, or heat sink compound. If you need more help let me know
Regards,
Spud
Jun 18, 2008 | Gateway Computers & Internet
Gateway Sb-4100-A PC Desktop Logo
241 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
