Question about Braun AromaDeluxe KF 580 Coffee Maker
Coffee maker timer does not keep the heat plate on after 10 mins.
I have a 10-cup coffee maker and it makes coffee of the gods, simply delicious! The problem I have been having lately is that when I make my coffee via the timer(and regular without timer), it will make the coffee and the red light only stays on for a max of ten minutes after brewing and turns off "automagically". I have only been noticing the issue since I set reset the clock for daylight savings. This might be the culprit, not sure though...pleeeeeeeeze help me, without my coffee I am useless!!!
Thank you so much in advance,
I was able to fix my little problem. I unplugged my coffe maker and waited 'bout 10 mins for the whole thing to shut down. Once the clock shut off, I reset the time. Secondly, I pressed the on/off button and held it in for 2 seconds until the red light started flashing. I set H to 1 and M to 59(I have never seen this before). anyhoo, afterthat, I set the timer to the exact time I wanted to smell my freshly brewed coffee. This morning, the red light seemed to stay on and kept my coffee nice and hot.
Posted on Nov 25, 2008
It keeps overflowing at around cup 9 and ruins the coffee in the process. Any idea why?
You should make sure you are measuring in the same cups they are alot of coffee makers measure in 6oz cups (I don't know why) but they do so over 10 cups that would be 20 oz difference
Dec 21, 2010 | Zojirushi EC-BD15 10-Cup Coffee Maker
Grx Bunn coffee brewer will not brew. I've followed all directions carefully. I've waited almost 30 min for it to heat up I've added more water and still nothing. Now I have been waiting for about an hour...
It sounds like the tank isn't full. It takes 2 full decanters of water to fill the tank in the bank. After pouring in 10 cups of water, close the lid and wait 3 min. Then open up the lid and pour in another 10 cups of water and close the lid. Then turn the vacation switch on and wait 15 min. Now you are ready to brew coffee. Place your grounds and filter in the funnel basket and pour in 4-10 cups of cold water and place decanter on warmer plate. Close the lid and in 3 min you will have a pot of coffee. If this doesn't happen, please call 800-352-2866 and we will be happy to assist you.
Jun 17, 2010 | Bunn GRX-B
The on/off red light keeps flashing and won't work when pressed. I cannot get anything to happen. It won't turn off, won't make my coffee. It just keeps flashing
I have a Blender whose light flashes. Im not sure why? however, if you unplug for 10 mins starts up again. maybe you should try this
Feb 16, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
The heater plate on cuisinart cbc-1600 coffee maker does not stay on after brewing cycle to keep coffee hot. is this normal operation?
The CBC-1600 comes with a thermal carafe. therefore, it doesn't rely on a heater plate to keep the coffee warm.
Feb 01, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee maker did not heat
An electric coffee maker has an electric flow-through brewing water heater with a heating resistor controlled by a temperature dependent regulating switch responsive to the temperature of the heating resistor, and a warming plate heated by the heating resistor for maintaining the prepared coffee at a desired drinking temperature. Apparatus for adjustably prolonging the interruption of heating current 2 to 5 times the normal cooling time of the regulating switch is connected in circuit with the heating resistor and the regulating switch, and a manually actuated small quantity control means connects the heating current interruption prolonging apparatus in circuit with the heating resistor and the regulating switch. The prolonging apparatus may be an adjustable auxiliary electric heater in parallel with the regulating switch and thermally coupled thereto or an adjustable timer in series with the heating resistor and regulation switch and triggered by the opening of the regulating switch
Jan 31, 2010 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Heating Element Shuts Off Very Early
Reset the timer for shutting off the hot plate, instructions are in the user manual.
Jan 31, 2009 | Cuisinart DGB-300 Coffee Maker
Manual or instructions
http://www.focuselectrics.com/supportdata/L5750_CocoaLatte_CM300_ALL.pdf
Downloads complete manual as PDF. I lost mine too.
Sep 21, 2008 | Back to Basics CM300 Coffee Maker
KitchenAid 10 cup coffee maker Model # KCM511ER-1 Ser# WGT4409334 Pushed the Brew button after a Min. or two it beeped and Replaced the time with "Err2". the coffe maker did not warm up or...
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If the code does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Aug 16, 2008 | Black & Decker Spacemaker 10-Cup Coffee...
Braun AromaDeluxe KF 580 Coffee Maker Logo
343 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
ellipse0904
Level 1 Expert
Jim Thurston
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
