Question about Maytag EPIC MFW9700S Front Load Washer
The ''control locked light is on'' how do i reset it
On a maytag frontloader
    President:
  • Maytag Master
  • 2,651 Answers
There is a button on the control panel, marked "control lock" hold for 3 secs to unlock, look closely its there
Posted on Nov 25, 2008
I have an F11 error code on my maytag frontload washer?
It sounds like a control unit has burned out. There is a computer that speaks to the motor to tell it what to do. If you reset it and a part is bad the computer will still recognize the problem and thus resend error message.
May 04, 2014 | Maytag Washing Machines
Have a Neptune Maytag frontload washer. The door is open but the lock mechanism is locked so cannot shut the door. Is there a code for this??
try un pluging washer for 15min and plug back in to see if it resets. if not u may need new latch but first make sure u don't have a loose wire to lock
Apr 06, 2014 | Maytag Neptune Washing Machines
I have a Maytag MSD2351 side by side and just replace the water filter. When I attempted to reset the filter light, the control locked and I can not get it to unlock. I pressed the lock and water button...
If the Control Lock feature has been enabled, the Control Lock light will flash 3 times indicating that it is activated. To turn off Control Lock, press and hold the Options key that says "Control Lock Hold 3 Sec" under it for 3 seconds. If the dishwasher has a dedicated Control Lock button in the Options selections, press and hold CONTROL LOCK for 3 seconds.
NOTE: You may need to disable Sleep Mode by pressing either Start/Resume or Cancel, or by opening and closing the door before you are able to turn Control Lock off.
NOTE: If your model requires you to press and hold PROSCRUB UPPER, 4 HOUR DELAY or BOTTLE WASH to lock the controls, the Control Lock light will be on when Control Lock is active.
Nov 03, 2017 | Maytag Refrigerators
Maytag dryer epicz says "controls
controls locked
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
To enable the Control Locked feature:
Press and hold AUTO DRY LEVEL for 3 seconds. Control Locked
glows and a single beep tone is heard. To unlock, press and hold
AUTO DRY LEVEL for 3 seconds. The indicator light turns off.
Jul 15, 2011 | Kenmore Elite HE4 Electric Dryer
My dryer has the controlers lock
Hello & Welcome to FixYa
Control lock light is displayed when the control is locked, to unlock the control you should reset it. To reset press and hold the END OF CYCLE/DRAIN-SPIN button for 15seconds. Please get back to me if you have any other questions.
Kevin
Nov 28, 2010 | Maytag EPICz 6.7 Cu. Ft. King-Size...
Have replaced the water filter - how do i reset/turn off the "change filter" light ?
Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4 Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • May 18, 2010 | Maytag MZD2766GES Side by Side...
    Maytag frontloader washer, seems to wash ok but won't spin water
    madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
    Aug 07, 2009 | Washing Machines
    I do not get the door lock indication on my maytage neptune frontloader washer, which prevents the high speed spin.
    what model is it if its the 3000 or 4000 u have to replace lock latch and top board not worth fixing if its thee 5500 model just the locklatch and its worth fixing
    May 20, 2009 | Maytag Neptune Washer
    Maytag EPIC MFW9700S Front Load Washer Logo
    348 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
