Question about Maytag Neptune MAH7500WH Front Load Washer
My Maytag Neptune 7500 front load washer will not turn on when the AC or heat is running
We own a Neptune MAH 7500 AWW front load washer and when the AC or heat is running the units electronic screen says Power Failure and the machine will not turn on. Any suggestions on how to correct the problem? Steve
Check voltages at the outlet. My guess is that you are on the HVAC circuit, and the Neptune is more sensitive than your hvac equipment. Also check that the neutral is about the same potential as the ground.
Posted on Sep 23, 2007
Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Does sound like it's not balanced properly, or maybe it's set on drip dry instead of spin , basic solution i know but often the best lol ,
Nov 26, 2007 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune MAH 6700 AWW. It is shutting off and giving error code tE. Customer service does not recognize the error code. Can you help?
This is a problem with the signal from the water heating element "Thermistor" a Thermistor is a solid state sensor that senses temperature, in this case water temp. The Thermistor is part of the washers water heating assembly and not sold separately from it. There is a factory repair bulletin associated with the problem and the new part has improved reliability. I can't understand what the Maytag folks you called would tell you it is not listed, it is a common fault in the Neptune. Please rate my help. Thanks
Jan 23, 2012 | Maytag Neptune MAH5500B Front Load Washer
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Oct 12, 2009 | Maytag Neptune Washer
Contol panel has gone blank and contol panel is hot on right side
try unpuging for awhile then plug back in if doesnt work need to replace board and panel
Apr 06, 2009 | Maytag Neptune Washer
Maytag Neptune MAH 8700 AWW
NF - No Fill
It means that the Washer does not turn on water valves to fill washer with water.
Try the following steps and the problem should be solved.
1.Is the water turned on?
2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Good luck.And please do rate my answer.Thank you.
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH7500WH Front Load Washer Logo
269 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
