Question about GE JVM2070 Microwave Oven
Shuts off starts for 3 sec then shuts off, screen goes off, then says to set time. reset time and starts for 3 sec and says to reset time
  • Anonymous Feb 09, 2009
    runs for a few seconds shut off and some times clock resets
  • 446 Answers
Change your electrical wall plug to a diffferent one, do not use extention wire pls, there is insufficient to drive your microwave, thats why it resets and restarts again
cheers
Posted on Nov 25, 2008
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
Our amana microwave starts, no problem,them within 15 sec shuts off, sometimes it will take 5 tries to start it. when it shuts off, clock is gone and screen is filled with x's.
sound to me that control board is being reset by something , (xx's on display tells me this) before taking in for professional severviceman to look at it try one thing move oven to another part of house (farthest you can get it ) and try using it , I have seen one time that LOcation in home affects microwave operation
Sep 10, 2014 | Amana Microwave Ovens
Solution-GE spacemakerXL microwave oven model:JVM16505H01 mfg.date:feb.2005
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
Stops every 59 sec.
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds. That's the giveaway.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for some of these models and have uploaded them to our site here and here to help you.
Hopefully these cover your model number, which you didn't mention.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jul 07, 2010 | Sharp R-1870 Convection/Microwave Oven
MY PANASONIC MICROWAVE SHUTS OFF AUTOMATICALLY AFTER 3 OR 4 SEC
Sure sounds like it is losing power. First check the fuse and fuse holder. These companies are using really cheap fuse holders and they do not grab the fuse tightly, thye get hot and start to melt the fuse. Remove the fuse and look for signs of heat or flux running from the silver ends of the fuse. if you see signs of it being hot I would replace the fuse and fuse holder. Make sure ALL connections are tight and give it a try. I search long and hard to find fuse holders I like and can trust to do a long term repair. if you cant count on a part, the repair wont hold up and then Its MY reputation that suffers, Damn companies always choosing the cheap way out on making parts. When I started repairing Microwaves, a Home Microwave cost about 800.00 I see them sell at certain stores for 18.88!!!! how can you have good parts in there for 18.88?? Nobody makes things to last anymore. SAD!!! Fill The landfills and buy a new one. except the new one is Cheap Garbage!! Since it goes blank it sound like it is losing power. Always could be outlet you have it plugged into. Try different location first, on different breaker
Aug 18, 2017 | Panasonic NN-SN657SMicrowave Oven
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
GE Spacemaker XL 1800 Micro - " Turns itself off after 2 sec. "
It looks like a component is short-circuited and then it acts to protect. Call a service.
Sep 21, 2017 | GE XL1800 1100 Watts Microwave Oven
I have a Maytag Model MMV5207BAB over the range microwave oven that crapped out after 11 mos use. No warning, just no power. The outlet is fine I have no power surge problems in my house. This is the...
There is an internal fuse which is located underneath the side\top shell. If you have no lights or control panel, this is the most likely cause. This is not difficult to replace.
Nov 08, 2008 | Maytag Microwave Ovens
GE JVM2070 Microwave Oven Logo
172 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
