Question about Goodman GMS90703BXA Heater
Goodman heater..no heat
The heater is in my cottage.when i left i put it on auto and it was working fine. when i came back the blower was blowing but there was not heat?
  • Anonymous Nov 30, 2008
    I have a goodman furnace. Turn it on and everything works fine for a little while than heat shuts off and blower continuosly runs. Ignition will not work again unless you turn power off the furnace and try it again.Sometimes will ignite but than the same thing happens. heat goes off and blower runs continuosly until you shut it down. Led light blinks 2 times but did see 3x once. 2 indicates pressure switch but i talk to a tech and he said it could not be the pressure switch because if it was the furnace would never ignite.
  • 1,420 Answers
If you look thru a small viewing window, you will notice a small LED light blinking. Count the blinks and then remove the front access panel. On the reverse side you should find a diagnostic chart indicating what could be the issue based on the number of blinks.
Posted on Nov 25, 2008
Gpg13300701
pull or disassemble that inducer clean out rusty, lubricate it with oil. Put it back it should work or you can replace it with new one
Feb 10, 2014 | Heating & Cooling
I have a goodman furnace model number gms80904bncc. When the temperature in house is met the blower continues to blow. Even if I put the thermstat in off mode the blower is still on
Hi #1 check thermostat : see if the FAN ON/AUTO switch is set to( auto ) and not( on)...If this is not the case turn the furnace switch off for 20 sec. and back on...did it stop? IF so the blower relay is sticking and must be replaced.
AUTO=BLOWER ON DEMAND/CYCLING
ON=BLOWER 24/7 all the time..
hope this helps
Nov 15, 2011 | Goodman Heating & Cooling
I have an issue with my goodman splitt system. It is a 2 ton unit. 2 days ago the heat would come on and when the temp came up to my setting the heat kicked off, but the blower kept running. it does not...
what is the fan setting at? If its set to on then it will rum all the time if its set to auto then it should only run in heating or cooling mode? It is located on your tstat
Dec 30, 2010 | Goodman Heating & Cooling
Blower does not work and heating element heat with
Check for power to the unit. If power exists, check your low voltage. Do you have 24volts to R & C at your thermostat?
Feb 07, 2010 | Goodman GMS90703BXA Heater
Goodman GMH950904CXAC with white rogers programmable stat. Turn the furnace on and the blower comes on whether there is a call for cool or not. Red led on control board is on, indicating OK. Disconnect...
make sure the blower is not set on rather than auto or the blower will run all the time. You might want to disconnect the thermostat and test the low voltage circuit to make sure the wires are not shorted
Aug 12, 2009 | Heating & Cooling
Fan and heater run fine but fan does not shut off for a long time
Check the diagnostic indicator.
1. If the blower runs for hours make sure the fan switch on the thermostat is set on "auto".
2. The furnace safety system must be in lockout. This is the furaces way of telling you there is a problem.
3 Most common problem is a dirty flame sensor.
Feb 20, 2009 | Goodman GMS90703BXA Heater
Goodman AR42-1 blower works on heat mode but not on a/c
You may have a problem with the board or the motor, as there is a separate speeds for heating and cooling. I would call a competent, NATE certified technician to daignose this properly.
Jan 03, 2009 | Goodman GMS90703BXA Heater
Goodman gmp050-03 heater
Either yourself or a Heating specialist will have to replace the gas valve.. Once installed you will plug unit back in which will reset power board and should work fine
Dec 23, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman GMP075-3 ignition problem
bad board,i have had several board failures on goodman
Dec 18, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman a/c works, heater will work fine then fan will stop
you have a circuit board acting up. Try keeping the fan in the "On" position. It will keep the blower on all the time but it may work. There is a built-in delay not allowing the unit to come on after you reset it with the thermostat, wait three minutes or so to see if it comes back on. I still suspect a bad circuit board.
Nov 21, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
143 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
