Question about Logitech Cordless TrackMan Optical Trackball
Logitech cordless mouse won't open on double click
I moved my computer and am using another person's wireless. I can't open any of my programs with a double click. I changed the battery and that didn't help. A computer guy checked it and has not been able to figure it out. It worked at my house, but not where I am now. The only way I can get into programs is to right click and open. I can't shut down unless I do a ctrl/alt/delete. Any suggestions?
  • Anonymous Mar 21, 2009
    Same here - with an MX Laser.
    I pulled the 'Mini Receiver' (looks like a USB jumpdrive) out of it's holder and tried it in my new laptop. It worked on the laptop...and on the desktop SIMULTANEOUSLY! I thought, 'how weird' and returned it back to the holder and it hasn't worked since.
  • 8 Answers
SOURCE: Can't reset my cordless Logitech mouse
you should hold the reset button on the receiver for 5 seconds. let it go and immediately press the reset button on the mouse once. If done in this order it should be ok.
Posted on Aug 23, 2008
cpenzes
  • 1102 Answers
SOURCE: Logitech Wireless CE 0682 Keyboard won't work but mouse does
did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
Posted on Jan 20, 2009
SUPERMAN_B_1
  • 294 Answers
SOURCE: Changing the batteries on a cordless Logitech mouse
hello ,on the bottom of your mouse there is a cover that you remove thats were the 2 aa batteries go. the cover has the wireless info on it you'll see a spot were you can use your finger nail to pop the cover off then after installing your batteries just pop it back on.
Posted on Mar 28, 2009
leecom72
  • 4806 Answers
SOURCE: LX7 Cordless Optical Mouse troubleshooting
Hi there.
Go to the control panel, in control panel you will see mouse, click on that and you will be able to set reaction times speed click times and all the mouse settings.
Good luck and thanks for using FixYa!!
Posted on May 28, 2009
prashanthcl
  • 460 Answers
SOURCE: My logitech wireless mouse stopped working,
pls checked it from computer shop.
Posted on Aug 31, 2009
Clicking issues on logitech wireless mouse
  • 1 Use the mouse on the same side of the computer where the Logitech USB transmitter is attached so there is a clear signal between the transmitter and the mouse.
  • 2 Check the USB transmitter that comes with the Logitech mouse to be sure it is correctly plugged into the computer. The red LED should be illuminated on the transmitter if it is connected properly. If not, the signal cannot reach the wireless mouse.
  • 3 Turn the mouse upside down to check the on/off switch. Be sure it is switched on.
  • 4 Check the battery compartment by sliding the top housing off the mouse to confirm the rechargeable batteries are installed correctly.
  • 5 Charge the batteries if the mouse LED does not illuminate. The charger cord plugs into the front end of the mouse and the other end connects to a free USB port on the computer.
  • 6 Clean the desk surface or other flat area if the mouse is not tracking. The problem could be dirt or grease interfering with the tracking ability of the device.
  • 7 Open the Logitech software called SetPoint, which manages the mouse, to troubleshoot button functions. Open the program by double-clicking SetPoint from the list of software on the computer, then click "Mouse Settings." Click the "My Mouse" tab and check (or uncheck) all the task boxes that are desired for operating different mouse functions, then click "Apply" and "OK."
  • Mar 17, 2012 | Logitech Cordless Mouse
    No matter how I set the buttons to act, for example make the right side button do nothing, it always does the default action which is to move down. I always hit that button accidentally as it is very...
    Logitech provides an excellent program called "Setpoint" which should have been included with your cordless mouse on a CD.
    This program allows numerous adjustments and options to your personal preferences in using your mouse.
    Should you not have the Setpoint CD, here is the link from which to download it:
    http://www.logitech.com/en-us/584/3131?wt.mc_id=usym_/setpoint_global&strf=Universal_Symlink
    Once you've opened the first page, click on downloads, click on the operating system you are using, then click on whether your OS is 32 or 64 bit. Most computers will use the 32-bit version. From there follow the steps in order to get this download. Once downloaded, install the program and then explore the numerous options and preferences you can make for your mouse.
    Best of luck to you,
    Thomas
    drbyte775
    Jan 20, 2011 | Logitech Cordless Mouse
    My logitech wireless mouse is acting funny, it does double clicks so whenever i try to drag something, it doesn't work. How do i fix that?
    well i have a promblem my mouse when i move it to the right, it moves left on the screen. why is that? plz tell me how to fix it!
    After a Low Battery Message, but with battery still functioning, I replaced the battery, clicked reset and had a dead mouse on my hands. I replaced new battery with the old battery to test -- still dead....
    You need to re-connect the mouse to wireless network.
    Follow the steps given below.
    Step 1
    Press and hold the Connect Button ( At the bottom of the mouse ) and the connect button on the receiver together and release both the buttons together.
    This will help you connect the printer again to PC.
    If this does not work, try this next step.
    Step 2
    You will have to uninstall and reinstall the drivers for your mouse
    Click on Start
    Click on Settings or Control Panel
    Open Add or Remove Programs OR Programs and Features
    Look for Logitech Wireless Mouse in the list
    Use the arrow key on keyboard till you select the Logitech Wireless and choose Uninstall
    Hope this should fix the issue.
    After you uninstall - reinstall the program, and restart your computer. This should allow you to use your cordless mouse again.
    Thank you for contacting FixYa
    *Please rate this solution with thumbs up
    Nov 18, 2010 | Logitech Cordless Mouse
    My Logitech Wireless mouse stopped working,I have changed batteries, restarted computer, nothing is working? When I change the battery the light is green when I first put it in but cursor doesn't move and...
    Welcome to Fixya Support
    I am Michelle, and i will be assisting you regarding the issue
    Please refresh the wireless connection
    in order to do so please press and hold down the connect button at the bottom of the mouse and the connect button on the receiver together and release both the buttons together.
    this should referesh the wireless connection.
    Nov 16, 2010 | Logitech Cordless Mouse
    My computer was refigured and I can no longer use the wheel on my Logitech cordless mouse for double clicking. What do I have to do to get this feature back
    1. Check that the batteries are loaded correctly and are fully charged.
    2. Check that the battery cover is properly secured.
    3. Check that the wireless receiver is connected to your computer correctly.
    4. Please make sure the wireless mouse and receiver have been activated
    6. Please make sure that the receiver is installed at least 20 cm (8 inches) away from other electronic devices (such as monitors
    or speakers) and no more than 100 cm (3.3 feet) away from where he mouse will be used.
    Jan 22, 2010 | Logitech Cordless Mouse
    Double clicking
    Access CONTROL PANEL.
    Access MOUSE.
    Set the "double-click" speed to your personal taste,
    to avoid "accidental" double-clicking.
    Jul 17, 2009 | Logitech MX1000 Laser Cordless...
    My Logitech LX5 wireless optical mouse has never worked properly
    hi im josh in cebu phils.may i help you? Friend try my gathered solutions. This problem has a simple solution—replace your batteries! Low batteries in a wireless device will cause all sorts of problems. In a mouse, this typically means that the cursor slows down, jerks around, or seems to hit an invisible wall. Fresh batteries should fix things right up.
    If new batteries don't fix the problem, you have some sort of wireless interference. Try moving the wireless receiver to a new position—preferably away from other wireless devices (wireless network adapters/base stations, cordless phones, baby monitors, and the like). If interference continues, see if you can change transmitting/receiving channels on one of the devices, or consider turning off the interfering device while you're computing. Good luck friend hope i helped you.
    Mar 04, 2009 | Logitech LX5 Cordless Optical Mouse
    The wireless mouse Double clicks on its own
    go into the control panel under mouse and make sure your settings are set to single click insted of double click.
    Nov 28, 2008 | Logitech Cordless Mouse
    Logitech Cordless TrackMan Optical Trackball Logo
    1,184 people viewed this question
    Top Logitech Computers & Internet Experts
    micky dee
    Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
