Remote model number is AR-DL1 We have to turn the power to the unit on and off at the meter box. Once the power is switched on the remote works all the functions except on/off.
Master cool evaporative cooler thermostat.   Timer hours (7 and 8) are flashing red....
(More)
Master cool evaporative cooler thermostat. Timer hours (7 and 8) are flashing red. However it does not seem to effect operation.
2008 Salem 26TBss worked fine when parked adn returned to find unit would not power on. No manual...
(More)
2008 Salem 26TBss worked fine when parked adn returned to find unit would not power on. No manual fan operation either. Found fuse under cover that keeps blowing the 3 amp fuse. Any Ideas ? And thank you for your time. Steve
fan air blowing out instead of cold air also operation and timer light blinking non stop this...
(More)
fan air blowing out instead of cold air also operation and timer light blinking non stop this happened after an power surge in our house circuit breaker
air handler should be a variable speed handler but i do not know how to adjust it. I would like it...
(More)
air handler should be a variable speed handler but i do not know how to adjust it. I would like it to operate at max rpm.
I have a 1990 Winnebago on a Toyota with a vent in the center of roof. Will the Dometic A/C fit and...
(More)
I have a 1990 Winnebago on a Toyota with a vent in the center of roof. Will the Dometic A/C fit and is wiring already in place usually?
