110 volt leg from an existing 220 volt outlet.
SOURCE: 220 volt dryer outlet is
If your home has fuses, one of the 30 amp fuses may be blown. If breakers, not as likely you have a bad breaker, but possible. Check voltage at main electrical distribution pannel. Look for loose connections.
SOURCE: 110 volt/amp dryer
yes ,i see some on line at living direct.its an Haier,they call it a portable.it was about 300$ and that included shipping.if you can't find .i googled 110 volt dryer and their was the link too [living direct] have fun,God bless,tom
SOURCE: is my dryer 220 or 110 volts
If your dryer has a standard cord (looks like a extention cord) than you can not hook it into 220, it is a gas dryer if you have that plug. If you have a electric dryer it will have a much larger plug and vcan only be plugged into 220
SOURCE: A diagram of how to wire a 220 volt outlet from
You can't really do that. The two 110 outlets probably come for the same 'leg' of the 240. If you check them with a meter, there will be '0' volts between the two hot wires. So, they have the same 'potential'. You need a regular 240 volt circuit from a double pole breaker that is rated for the wire size that it's feeding. 20 amp-#12 ; 30 amp- #10 etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
