Question about Tecnik TKC1285 Dual Fuel (Electric and Gas) Kitchen Range
Element the element in my cooker has blown 5 times in 4 years why? is it the element or is it the cooker
0 characters
1 Points
Stove about 4 years old started blowing fuse in house main box. Replaced fuses worked 24 hours now it blew again stove was not in use at the time. When it blew 2nd time the fuses were extremly hot.
This indicates that one of the heating elements or control has developed a problem. Can you provide the make and model for this range?? Replace the fuses if blown. Check to see if any element is hot - including those inside the stove. Note any that are. Shut off the stove and unplug it from the outlet. When cold, perform a careful visual inspection of the heating elements on the cooktop AND both the bake and broil elements inside the oven (especially any that were found to be hot earlier). Run your fingers along the blind side of the elements to detect any openings, blobs, etc. in the metal covering of the element. Replace any damaged elements with new. Start the process over again - especially the new element. If found hot - check the control - is it on? The control may need replacement, too. This may require more skills / tools than you have and need a pro. Good luck!
Apr 10, 2015 | Kitchen Ranges
How fix blown element on Electrolux induction range?
If it's a year old and under a 5 year warranty then it will be covered under the warranty and shouldn't cost you a dime. If it happens again then speak to someone about getting a different range since you may have received a lemon.
Nov 01, 2012 | Kitchen Ranges
Was baking in oven on a baking stone and inside the oven there was a flash and loud pop (what you would expect if you had metal in a microwave). Is this worth the service charge to see if it can be fixed?...
Was the baking stone resting on the element? It sounds like the element has shorted out and it should have tripped the circuit breaker and/or blown a fuse in the unit. Replacing an element is not difficult and is carried out from the inside and the back if the oven. With the power off, locate which element has blown, it will probably be the bottom one and there should be a hole at the site. Remove the back if the unit, remove the wires from the element, remove any screws that may be holding itin place, ease the element out of any clips that retain it and pull it out through the front, Refitting the new element is the reverse of the removal.
Jan 18, 2011 | Amana AER5712AA Electric Kitchen Range
Hi, I have a Rangemaster 110 (electric double oven), which has a double grill. Unfortunately one half of the grill has blown - not working. Is it easy to repair? Thanks a lot - Krisztina
Usually fairly straight forward. Remove the blown element being careful not to loose the wires into the void behind the grill. Insert new element making sure the orientation and wires are conected as the original was.
Dec 28, 2010 | Rangemaster Range Cookers Kitchener 110...
Can't find parts for Lofra range cooker
do you have a clue where i can grip some knobs for lofra gas cooker.
MXUD66GGI. i have tried every where can you help me.thanxs.
Jul 15, 2009 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Creda C461E Cooker
the control thermostat may also have been burned out. check it.
repair manuals can be located from here.
Nov 10, 2008 | Creda C361E Electric Kitchen Range
Hotpoint ew83 main oven stopprd heating, fan and light ok but no heat from element
Hotpoint EW83
1. Safety Fusible Link Blown (O/C) Do continuity test
2. Temperature Control Module Faulty (Heat Sensor)
3. Main Heating Element Blown (O/C) Do Continuity Test
4. Check for damaged wiring due to arcing etc.
5. Fetch the Proff!
May 04, 2008 | Kitchen Ranges
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Rangemaster Toledo 110 oven/Grill element
How easy is it to fit a new grill element. The element on the left hand side of the grill is not working so I need to replace this. I'm just wondering if this is easy to do myself or do I need an
Dec 15, 2007 | Kitchen Ranges
Cooker keeps tripping the electricity supply.
If the main oven is electric, disconnect the heater element and try, if no trip operqates. then replace element.
Nov 22, 2007 | Belling CookCenter 151 Dual Fuel (Electric...
Kitchen Ranges Logo
14 people viewed this question
Top Tecnik Kitchen Ranges Experts
Richard Roth
Richard Roth
L Pfaff
L Pfaff
Are you a Tecnik Kitchen Range Expert? Answer questions, earn points and help others
