I have a older kenmore limited addition model #911.7398910 all of the sudden it will not light, when i go to set the temperature it stays at 100 degrees but does not go up and all of a sudden there is a little red light on the bottom right hand side that says on that i have no idea why> is something wrong with my oven or is something on that i do not know?
If your Kenmore unit's model number starts with 790, an F10 error means that the oven temperature sensor is seeing a runaway temperature reading. This could mean that the sensor or the "clock" (electronic control unit) is bad. (Sometimes it could be the element but usually you'll see that easily.)
Unplug the unit (or flip the circuit breaker to off) for about 30 minutes to reset the error. If it recurs, you'll need to do additional troubleshooting to determine the fault. Please add a comment with the complete model number of your oven/range for additional assistance. searspartsdirect.com will probably have a parts diagram and parts list for your oven or range.
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Range "Older Style" F2
Oven too hot
Replace relay board (if present) or oven temperature sensor
Range "Newer Style"
F2
Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode.
Ohm test the oven temperature sensor, if OK, change power relay board.
deffintly a sensor problem a high limit may be faulty and needs to be replaced do you have a Johnstone in your area? if so buy the high limit a few bucks and replace itif you are handy.
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
you can get the model number and serial number from the oven, just open the oven drawal and get the number and call the customer service from where you got this oven from.
