Question about BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620
Threading film in a Keystone Model K 109 Projector
I purchased a projector and it came without a manaul. Iwant to know how to thread film for viewing
2 Suggested Answers
SOURCE: Keystone 8mm movie projector
Re Keystone 68 projectors:
I join the growing throngs of folks who wish to view their family archives in 8 mm before submitting the reels to the digitals for conversion. Doesn't anyone have an answer for us? I continue to search, if I find, I'll post.
Fauvette
Posted on Jan 21, 2010
Need a manual for Keystone 8mm movie projector Model K-77.Thanks
Try Googling (keystone)(K-77)(manual) without parens.
Apr 16, 2018 | Office Equipment & Supplies
I have a Keystone K75. The film will not stay in a loop after going through projector so it goes through too fast and you cannot watch the movie. Any ideas of what is wrong?
When threading the projector you must have a loop of film before and after the film gate (the part that swings open). You can also try turning the projector on with no film in it and make sure both upper and lower sprockets are turning. If this is a new problem you might have a broken belt or gear inside. Take it to a camera repair shop and they can tell you more.
Jan 05, 2015 | Office Equipment & Supplies
THREADING FILM IN A ELMO FP-C PROJECTOR
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm.
Jan 10, 2013 | Sewing Machines
HAVING TROUBLE THREADING FILM - ELMO FP-C
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
How do you change the lamp in a mod # 980Z keystone projector
There is a black and silver knob under the keystone label( right above the automatic label ) on the side of your projector. turn this knob counterclockwise to loosen the covering over the housing unit for the lamb. once the knob is loosened lift the housing unit off of the side of the projector. You wlll see the enclosure where the lamp fits into beneath it.
Make sure the power is off for your projector while doing so. Screw the lamb into the enclosure , then replace the covering and screw the black knob in clockwise until it tightens.
Sep 21, 2012 | Office Equipment & Supplies
Instructions for mr christmas motion projector Iwant to know how to change slides
1. Unplug the power cord from the power source.
2. Loosen the knob screw to its extreme open position.
3. Pull out film from the projector and replace with a new film by screwing the knob tight.
IMPORTANT: Always place the film with the silver surface face down to avoid film damage.
If you would like to have a copy of my instruction manual, please send me an email to LBrown18062@hotmail.com I will send you the manual right away. Lawrence Brown
Oct 06, 2011 | Office Equipment & Supplies
How do I angle the projector at the side of a screen & get the screen view of it straight?
In projector menu you will find a setting called 'keystone correction'. Use horizontal and vertical keystone correction to correct the projected image.
Sep 24, 2011 | NEC MultiSync MT1030 Multimedia Projector
Bell and Howell 16 mm diagram . don't know how to thread the film
Check this Website and see if one of the manuals doesn't give you the answer:
http://www.paulivester.com/films/projector/BH273man.htm
Jul 02, 2017 | Bell & Howell Photography
Fauvette
Jul 12, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620 Logo
174 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
