Question about Makita BMR100 Radio
Makita radio blinks e
Put battery in radio and the e came on the screen blinks for a couple seconds then goes off this is the second radio that ive gotten that has done this i even tried the power cord yet nothing was wondering if there is a reset button or what i really dont want to buy another one
  • Anonymous Dec 03, 2008
    My Makita radio shows 'E' when plugged in, but I found a break in the power cord right below the transformer. This is the whimpiest power cord I have ever seen, especially for something that is built for the job site.
  • csm0005 Jan 20, 2009
    The power cord pulled apart by the transformer, so i got another one with the same amount of voltage but the radio will not work. Occasionally when I plug it in the 'E' will appear and the radio won't work, but when it does work the screen will show the radio stations but the blue back light does not come on and it does not pick up any radio signals. I'm not sure what to do in this case, do you have any suggestions?
  • 23 Answers
Usually the blinking E means the backup batteries are dead.
the backup batteries are AA and should go in the lower compartment on the rear of the radio.
just make sure you install the backup (AA) batteries in first, then insert your main battery to run the unit. doing it backwards wont always clear the "E" notification
Posted on Nov 26, 2008
  • Stephen Webster Oct 25, 2012
    i have done all this but its still not working any more solutions
Makita worksite radio ,a sparky told me to use a plug with a low fuse in it instead of the ac adapator turned it on and it went phhhtt!!! is it ruined or is there a solution?
Posted on Jan 02, 2010
  • bdam Jul 13, 2011
    It is probably broken, with and ac adapter u are actually changing the voltage from 120v to 12v . So instead of giving the radio 12v you introduced it to 10x that much. I would open it up and see if there is some sort of fuse inside. Also I wouldn't get any more advice from that sparky.
Matika brm100 flashes e i found that the power socket on the front was faulty had no negative feed to radio
Posted on Mar 05, 2010
  • bdam Jul 13, 2011
    Was this when it was plugged in or running on a makita battery?
  • tom edwawds
    tom edwawds Oct 05, 2014
    plugged in
Frozen mobile touch screen
sounds like you bricked it. try taking the battery back out than hold the power button for 5-10 seconds than put the battery back in and try it than.
Dec 10, 2013 | Samsung Cell Phones
I power on my lenovo g55o, the power light come on, the battery charging light and the hard drive blinks for a couple seconds and goes off, but the monitor never lights up
You can try switching off computer, unplug the ac adapter, then the battery. When all power source are removed, hold the power button. Then put the battery back on then try switching the laptop back on.
Mar 12, 2011 | Computers & Internet
It got a very slight amount of water splashed on it, and now when it is turned on it automatically goes to the push reset button screen and wont go any further. Ive gotten the set time screen to show for a...
Unfortunately, I had this problem before with a waterproof camera!
Once the water bridged the circuits, it did irreparable damage.
If it had dried out WITHOUT voltage running through the camera, it might not have caused any issues.
Best option is to remove any batteries and power cables, and let it dry out completely. Check to see if the problem persists, and if so, consult the manufacturer for a repair.
Feb 23, 2011 | Panasonic PV-GS39 Mini DV Digital...
Radio receives but will not transmit. Call button will also not transmit. The LED on good radio blinks once every two seconds. The Led on bad radio blinks once every three seconds. Do I trash the bad...
Here are a couple of things to try before trashing the unit:
1) Check your programming to see that your frequency, code and Qt filter (if any) match identically. For simple operation set your Qt filter and code to off (zero).
2) Swap the batteries between the two units, see if the problem moves to the other unit. If so, you have a bad battery pack.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5320_T5410_T5420_User_Manual_E.pdf
Best regards.
Aug 11, 2010 | Motorola Talkabout T5420 (14 Channels)...
My problem is exactly the same as the original poster's.
It may be that there is a setting in the camera that has been changed to make the camera only operate from the computer. I suggest looking around the menu in the camera when it is attached to your computer.
Aug 27, 2009 | Kodak Easyshare M893 Digital Camera
I have a Solo Radar Detector and all of a sudden when you insert the batteries and turn it on, it goes through the motions of turning on, then when done, the solid red light just blinks. I don't have a...
Well first off in doing so removing the batterys before you powered it off its stuck in some kind of error mode. Try putting the batteries in, holding the power button down for a few seconds and see if the light stops blinking.
Second Idea if you have a local radio shack they have replacment power cords for radar detectors there about 10 dollars. I had to go buy one for mine. After powering it up with that Id say it should work fine.
Feb 22, 2009 | Passport 8500 Radar Detector
Sony KP-57HW40
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Feb 19, 2008 | Sony KP-57HW40 57" Rear Projection...
Tv goes pink....
I cannot, in good faith, go about recommending shops, as I am not in the referral business. However, Ruckers TV in Arlington has done me right in the past....accordianman
Feb 09, 2008 | Televison & Video
Screen goes blank when I plug camera into computer
I have to say Mac's I know nothing about. But the simple way would be to purchase a universal USB card reader- and use that.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Makita BMR100 Radio Logo
7,390 people viewed this question
Top Makita Audio Players & Recorders Experts
Marvin
Marvin
Gil Shultz
Are you a Makita Audio Player and Recorder Expert? Answer questions, earn points and help others
