Question about Frigidaire FGQ332ES Gas Dryer
Frigidaire Gas Dryer not heating up. Other elements are all ok.
It seems like everything is working fine except that it does not geenrate heat. Motor and drum are running well including the switches. No lint in the machine at all. I would like also someone to instruct me how to open the dryer so I can replace the part. Thanks
  • 1 more comment
  • tlowery643 Dec 29, 2008
    Same problem but ignitor clicks, glows orange, clicks again and have flame that is hitting top of round enclosure it is housed in but dryer is still not heating and with fron panel back on I can hear the ignitor or something click every few minutes as theough the air through the enclosure I guess may be blowing flame out because it burns fine and doesnt reclick with front cover off watching it. An y Ideas? Frigidaire FSG447GHS0 dryer.
  • Anonymous Mar 29, 2009
    dryer also won't heat. Manual says the unit has two house fuses but I can't find them..
  • pay1298 Mar 29, 2009
    mine won't heat up either. Manual says two fuses but doesn't tell me where to find them. Luckily I bought the three year warranty. Mine won't click or anything, just turns
  • 33 Answers
It sounds like your igniter is no good. At all costs, check the Fuse before anything else. It is usually accessed from the back of the unit.
Posted on Nov 25, 2008
My dryer only gives out low heat, does not get very hot ? machine is 15 years old
Posted on Sep 01, 2009
My Blomberg 1330A stopped heating. Heating element seems fine, so now looking for the thermal switch...
Test the heating element with a meter for continuity with a meter.
After that follow the wires, one thermal fuse should be neer the heater element the other near the exhuast.
Jan 12, 2013 | Dryers
Dryer won't start
have you left the unit unplugged for one night and tried to start??
doe sit make any humming noise when trying to start
Aug 25, 2008 | Frigidaire GLEQ642A Electric Dryer
Frigidaire dryer, looks like the heating element is good. no heat, all else works fine
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 12, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Dryer seems to work (runs, tumbler turns, timer works, air flows) except there is no heat. I see that there could be several reasons for this, how do I isolate the problem and fix it?
First look for reasons why safety components would trip and remedy them thangsthemobilian_1642.jpgthemobilian_1643.jpgthemobilian_1644.jpgthemobilian_1645.jpg
So once we have that ironed out we now have an idea where to look first. If the dryer is clean and the vent is clear and you still have no heat then one of your heating components have failed. The heating components are the element, coils, sensors, ignitors and controls.
So if the element is bad simply replace it and you now have heat but what if the element is ok?
themobilian_1648.jpgthemobilian_1649.jpgthemobilian_1650.jpgthemobilian_1651.jpgthemobilian_1652.jpgthemobilian_1653.jpgIf your ignitor and flame detector is fine you may have the very common problem of weak coils themobilian_1654.jpg
If it turns out thet your safetys are fine and your heating components are fine then you could have a bad controlthemobilian_1655.jpg
If your control is fine you could have a bad circuit breaker.The motor on American machines is 120 volt of alternating current but the 5000 watt heating element requires 240 volts.themobilian_1656.jpg
I have include a dozen or so Dryer service manuals and more HERE
Let Me Know.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 03, 2011 | Dryers
The dryer starts up and seems to run fine except that it doesn't heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 30, 2010 | Frigidaire GLER341A Electric Dryer
Frigidaire gas dryer, gallery series model GLGQ2152ESO - no heat,
heatman101
Jul 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
Dryer will not heat
Have a certified electrician check your outlet. The dryer requires 220VAC for the heating elements to work. If this is ok, check the heating elements it may be broken.If this is ok, check the high and low limit switches, this could be defective.
Apr 04, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
There is no heat
Disconnect power and access your dryer fuses. Check and test your fuses for "continuity". Most likely, a white thermal fuse. Can possibly be your ignitor or heat element as well. Is your dryer gas or electric?
Jan 27, 2009 | Hoover Dryers
Frigidaire FGQ332ES Gas Dryer Logo
1,552 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
