Question about Brother Office Equipment & Supplies
When typing, a letter is hit but a number is being printed. Typewriter is a Brother CE-500 model. We think you need to use the "Code"function but the manual has been missing for some time
    Genius:
  • 2,120 Answers
Turn typewriter off, hold down CODE, turn machine back on.
Make sure you are not set for PROPORTIONAL SPACING.
Remove print wheel, turn machine off, reinstall print wheel, turn back on.
Posted on Nov 25, 2008
Typing letters not typed I think it has something to do with TW but can not seem to remove it from memory
If you aren't in KBII or a language mode or P.S. pitch the printwheel homing pawl is probably broken. You need a tech.
Jun 15, 2011 | Brother ML-500 Typewriter
I began using my typewriter this morning...and when I press a number or letter...it types the wrong number, letter, or symbol. For example, I press the letter "F" and it types a number...
Turn it off and on it should go thru it's dance and rehome the print wheel. f you are notin KBII , language mode or the print wheel damaged the homing pawl for the P/W is probably broken you need a tech.
DickyO
Jun 09, 2011 | Brother SX-4000 Typewriter
I cannot type numbers? how do i reset or what keys should i use so i can type numbers/figures?
the numbers should print just by hitting the key, just like the letters. if the keys are just dead, you may have a bad keyboard or main circuit board. take it to a repairman or get a new machine.
Mar 21, 2011 | Brother GX-6750 Typewriter
Is there a way to set typewriter to type numbers and uppercase?
There may be a caps key. You can get a manual @ brotherinternational.com, click on support.
DickyO
Apr 20, 2010 | Brother SX-4000 Typewriter
Brother EM530 Typing Wrong Letters
Hi there. Take out the printwheel and see if any of the spokes are bent. That would cause wrong letters. . Also if the print solenoid(piston) does not go in and out freely. Lawrence
Aug 06, 2008 | Brother ML-500 Typewriter
Printing wrong letters and numbers
Typing wrong letters.
Please help immediately
Apr 28, 2008 | Brother GX-6750 Typewriter
Brother ML-500 Typewriter Typing the wrong characters
The printwheel is not in correctly. the printwheel has a bent spoke or the printwheel homing sensor needs cleaning. Lawrence
Feb 14, 2008 | Brother ML-500 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
