Question about RCA RP-9316 Boombox
When I want to play a CD the read out says ''rEAd''.
What does "rEAd" mean? How can I get my CD to play?
  • petiepoo Dec 19, 2008
    LCD screen says: "rEAd no disc
  • 36 Answers
Its trying to read the cd. Sounds like you have a problem with a dirty laser or a incompatible disc. You can try getting some rubbing alcohol and a qtip dip one end of it in the alcohol and then rub it on the laser lens in a circular motion. Let the lens dry and try playing a cd again. Hope that helps.
Posted on Sep 17, 2014
Which fuse is it to take out if the cd player reads unreadable disk for any cd I put in...2006 Hyundai sonata...
Kirk, I am not aware of any fuse to remove to make player work. Try cleaning the lazer/head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CD player doesn read disc
2007 Sonata Ltd CD player won read discs
How to Fix Car CD Player
May 19, 2016 | Hyundai Cars & Trucks
Why doesn't CD player read discs?
If it's the CR-Rom of a computer, please restart your computer.
If the failure persist, means that the optical reader of your CD player is fauling.
No sure it should help but clean your optical reased.
Hardware 101 Cleaning The Lens Of Optical Disc Drive
Actually the same goes for a standalon player.
With costs as low as they are currentl, you sinply should remove the CD player of your computer and intall a new one
If this is not the answer you expect is because your question was not well specified.
Oct 26, 2015 | Audio Players & Recorders
When I load a cd in my Stanton C324 it reads "No
Hello
Clean your CDs before and after playing them. Although the compact disc has a much longer lifespan than does something like a cassette tape, it can be more fragile. Scratches, dust or other damage to the data side of the CD will cause many CD players to fail to read the CD or cause the CD to skip.
Examine the type and format of the compact disc if your CD player fails to read it. Verify that your CD player can read the type of CD and the files contained on it. Just because you've burned a collection of songs to a CD, for example, doesn't mean that your CD player will be able to recognize that information. You must burn CDs in a specially formatted "Audio CD" mode to play them on a CD player, or your CD player must be able to recognize the MP3 file format. Some CD players have limitations on the type of CD they can read. Verify that your CD player can read CD-R, CD+R, CD-RW or CD+RW compact discs.
Update your CD player's driver, if your CD player is a drive connected to your computer. Click "Start" and select "Control Panel." Click on "Hardware and Sound" and select "Device Manager" under "Devices and Printers." Right-click the icon for your CD drive and select "Update driver software." This may solve any issues the drive was having with playing CDs.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Stanton C324 Mp3 Cd Player With Effects...
I have 2006 chevy impala What does it means I try to put my cd in to play its say error
It means that your CD player is not reading the CD , try a different CD and preferably original CD and see if it reads it then. If the CD player works ok then, you had bad CD and if it should read error again then the CD player it self is defective.
Jan 22, 2011 | 2006 Chevrolet Impala
My IBM R51 laptop can't read any other cd/vcd
its either its a lens problem or that was how the CD/DVD Drive was made.
There are some drives that doesn't play white face discs, that is, they select disc and don't play all CD's, so maybe yours fall under this category.
How long have you been using your laptop and has it ever played Cd/Vcd's before?
If it plays them before, then it means your drive's lens is weak, but if it has never played them before, then it means that's how the player was made.
Which ever way, you still have an option of replacing the drive if you wish.
Take care.
Apr 14, 2010 | HP Compaq nx6115 Notebook
Doesn't read the cd. says
If any cd player does not play, three things, it either the wrong format, dirty cd or faulty cd player. If your cd player play others cd, it mean others are the wrong format. for example older cd player is not compatible to play some of the cd formatted from the computer. if the cd player does not play anything that mean the cd player is faulty.
Aug 27, 2009 | Sony Audio Players & Recorders
Emerson 3 disk CD player - CD spins - message
im not sure what toc read means, my cd player says that im guessing it means its loading, any ways take the d player apart an clean the lens wit a cuetip that should work, or the cds may be to scartched to read
Oct 15, 2008 | Audio Players & Recorders
JVC XL-SV22 Video CD
if cracks having in disc mean some times header does read disc! clean your header with disc cleaner!
Jul 01, 2008 | JVC XL-SV22 CD Player
LG LS50 DVD/CD-RW DRIVE won't recognize blank dvd-r
Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
You can burn only on the blank CD-RW or any blank CD.
Jan 17, 2008 | LG X-Note LM50 Notebook
RCA RP-9316 Boombox Logo
179 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
