Question about Maytag 24 in. MDB5601AWS Stainless Steel Built-in Dishwasher
Maytag quiet series 300 model mdb5601aws making noise
My maytag is making a grinding noise throught out the wash cycle im pretty sure its not the pump because it pumps the water out without no noise at the end of the wash. Ive taken it all apart found no debris stuck in any of the parts. The motor spindle spins free with no problem dosent seem to be loose or have a bad bearing but the noise seems to be coming from the motor area I cannot be sure. I would hate to replace the motor if that is not the problem any help would be greatly appreaciated
Thanks,
  • dmartins1406 Dec 30, 2008
    I have the same grinding noise issue. Started doing it occassionally and last night grinding/humming noise lasted through the entire cycle. Is there something that I should disassemble and clean out. What is the macerator? How do I get to it? Thanks
  • Anonymous Apr 16, 2009
    I have the same problem - got a new machine in '07 and it had to be replaced by year end due to same problem (it was under warrenty then). Now, a year and four months later going out again...the parts were over $300 when it was under warrenty, which was almost the price of the machine!
    Sergeant:
    Champion:
  • 338 Answers
Sounds like the macerator is bent out of shape from something going through the pump. Get a impeller kit and replace all the parts and you should lose the grinding noise. I can look up the part number if you want
Posted on Nov 25, 2008
We have the same problem, the repair guy told us it was something being chewed up by the garborator in the machine. turned out to be a piece of plastic from the factory.
It is doing it again, about 1 yr later. I have no idea how to get to the part I need. Do we get to it from under the machine? I think that is how the repairman did it before, buut not 100% sure.
Please let me know.
brenda.parsons@hotmail.com
thanks
Posted on Dec 25, 2009
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
Loud noise
Check for bones/glass/ceramic from chipped plates in the food chopper (for lack of a better term). You'll need to disassemble the entire lower arm unit.
Sep 06, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Maytag Quiet Series 300 Dishwasher not working (Model MDB5601A)
While I am not directly aware of the controls on the dishwasher I'd unplug it for a minute or two to see if the control reboots (for lack of a better term) I've seen many electroic devices that on occasion have this type of problem and simply taking the power from it may correct it.
I hope this helps,
Tom
Aug 22, 2009 | Dishwashers
Maytag Quiet Series 300 Dishwasher not working (Model MDB5601AWS)
in such cases it is always the control panel(touch panel) that needs to be replaced.it is very simple 2 chg and u could save lot of money.to chge cntrl panel ,open the door and remove all the screws around the white plastic part of door.then pull apart the inner part from outside part.the cntrol panel is held to outer panel with 4 screws.b4 that remove 2 screws holding the control board to panel.do not forget 2 unplug the unit from power b4 doing anything.
Aug 21, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Will not start wash cycle
Sound like the lid switch has went out , you should hear it click when the lid is close to an inch of being closed , they are un-expensive and easy to replace and they go out often from use. Easy to find online with your real model number located under the lid.
Phil
The washer with the grind noise is a main bearing going out and may be covered under warr. through maytag.
Apr 11, 2009 | Maytag Atlantis MAV7000
Maytag dishwasher legacy 300 quiet series
Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
Maytag 24 in. MDB5601AWS Stainless Steel Built-in Dishwasher Logo
1,178 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
