Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Tv won't show picture - black screen
We haven't used our tv in a couple months (we moved and never brought the tv with us until now). Last year our tv indicated we were going to need a new lamp we bought the lamp but never replaced it because the picture was still fine. Once the tv was brought here this year, the tv turned on fine (picture came up)--and this was maybe 2-3 months ago. Today, we turn the tv on and you can hear the tv come on but no picture. The green timer light came on and blinked then the red light under lamp came on. So we replaced the lamp (with the new lamp we bought from mits. last year) and the tv still wont show a picture. The light blinks green once turned on then goes to a steady green, but still no picture. We take out the lamp and put it back in, and the tv picture still doesnt come on (black screen) and the light blinks green, but now, red light comes on. Not sure what to do. We definitely can't afford a new tv at this time nor pay someone to come fix it. Hope this doesnt sound confusing.
  • Anonymous Jan 20, 2009
    i feel for yah mahn! mine wont show up. it used to be it wont show up for like, 2 minutes but i left it 4 like 1 hour but it wont show up!
4 Suggested Answers
  • 146 Answers
SOURCE: Lamp light turns red
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
Posted on Nov 15, 2008
  • 8617 Answers
SOURCE: no picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
Posted on Jan 26, 2009
  • 8617 Answers
SOURCE: Lamp problem
The DM is failing to complete the boot sequence thats why the power led is continuously blinking green. The V26 DLP DM repair kit will usually repair that issue you can get the kit at the following link which includes the replacement capacitors and step by step instructions with pictures on how to do the repair.Its listed under the repair kits category.
Posted on Mar 26, 2009
The tv will not show a picture
take a look at this, also make sure your screen is not cracked by using a flashlight and taking a close look
Dec 04, 2013 | Emerson LC320EM2 32" LCD HD Television
Soniq qsl322tv5 flat screen tv says
Hi, Unplug the TV for 1 hour and try again. The TV will reset to default. Good luck
Dec 26, 2011 | Televison & Video
My Sony Trinitron 36'' model#: kv32v26 is taking a long time to show picture when turned on. The sound comes on and the red light blinks for about 3-5 min. before the picture turns on. And when i switch to...
Hi Matt.
I`ve been repairing sony tv`s for a long time now and i can tell you that what you described is sure signs of a weak picture tube.
And the price of a new picture tube makes it prohibitive to replace it. You could open the set and adjust the screen control on the high voltage transformer but it won`t last long. If you decide to do that , look for a transformer with a long and thick red wire that connects to the back of the picture tube , That is the flyback transformer and there will be two controls on it, you want to adjust the bottom control that is the screen control(the upper one is the focus).
Turn your tv on and slowly turn the screen control up until the picture shows up at a reasonable brightness level, if yout turn it to high or you may get retrace lines in the picture.
That may strech the life of your set for a couple of months .
Hope this will help. Merry Christmas
Dec 16, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Black screen
screen belt is cut off. send to us
Jun 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Apr 07, 2009 | Sharp LC20SH7U Television
Picture on Telefunken 72 cm TV expands beyond screen size
Your screen somehow got switched to theatre/cinema mode. There is a setting on the remote that attributes to aspect ratio. Sometimes it is called "ASPECT". Look for it, and press it until your original screen aspect shows.
Dec 15, 2008 | Apex Digital PF2020 20" TV
Picture goes off and on...
Most likely your Cathode Ray Tube or CRT is going bad. That model number reflects an older TV. What you are describing is a fairly common problem for that television. If you bump the TV and it improves or gets worse then you know there may be a short.. Either way, I would recommend that you use our Premium Service or use our online resources to find a repair person near you. Good luck.
Jun 20, 2008 | Sony KV-32V16 TV
27 in Magnavox Smart TV
problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
May 02, 2008 | Philips Magnavox 20MS233S 20" TV
Sound but picture is barely visible on Sylvania flat screen
it is fixable, but you need to take it to a repair man to do that job. good luck
Mar 02, 2007 | JVC AV-32FA44 32" TV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
2,709 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
