Question about Philips SA3125\02 MP3 Player
I plug my mp3 player into the computer to charge and it turns off
My philips mp3 player over the last few months has been acting strange,occasionally when i i was using it it froze then it said error and ever since, i plug it in th computer and it starts to charge then turns back off
  • 8,596 Answers
Run a repair in the Philips Device Manager - make sure the lock switch is disengaged first.
-Tha Mp3 Doctor
Posted on Jan 17, 2009
How dont know how to charge my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Philips GoGear Flash MP3 Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
MP3 player won't turn on.
Well its a software problem so try connecting it to your pc and format it....i think sa kinda virus affected your mp3 player
May 30, 2010 | Philips SA3025/37 Flash MP3 Player
My mp3 player is not detecting the device when connected to the PC though de drivers r installed
As with any USB problem, check the cable integrity, check it's plugged-in securely, then if not that, try a different USB port. Finally, try leaving it plugged-in overnight to charge, as some players act strangely when their charge is absolutely depleted.
I could write it in txt-spk if you can't understand the above.
Aug 30, 2009 | Philips GoGear SA178 MP3 Player
My Philips GoGear MP3 Player is stuck
Been using this for a few months. Froze up on same song while on vacation last month, and continued to play same song on repeat until battery went down. Now is frozen with "Do Not Disconnect" as it was being charged on my laptop. Attempted to unplug and plug back in and Windows gives DO NOT DISCONNECT!!!!!
I am having the exact same problem!!!!!
Aug 02, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips Go Gear 1BG not turning on
The battery could be bad.. They only last around 1 year.. IF the battey is bad id could give off wrong readings too...
I would try a new battery..
Rate well ;o)
Jul 22, 2009 | Philips Sport Personal CD/MP3 Player
Player Will not turn on
if you turned it on before you charged it when you got it, that may be the problem, i would take it back to the store, get a new one, and charge it immidiately and make sure you use the disc to install it
Apr 17, 2008 | Creative Labs Zen V MP3 Player
Will not charge
batterys dead, these usually last for about 12-18 months.
you can probably buy a replacement, but may have to get the shop to fit.
Due to data loss et,c.
Use it on the computer with a USB lead.
Mike @ Compurepair.
Feb 25, 2008 | JVC XA-F107 MP3 Player
Freezes and wont charge
Try repairing the device:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
You may have to charge the device fully for 3 or 4 hours AFTER this process is complete.
-Tha Mp3 Doctor
Jan 31, 2008 | Philips SA5125/37 MP3 Player
PHILIPS GOGEAR HDD060 DOES NOT TURN ON
Here's a better solution - no offense, silly girl. First, find out if the computer will recognize the GoGear when you plug it in. If so, then use the Repair function in the Philips Device Manager.
If the computer doesn't recognize the player: Disconnect the GoGear from the computer, and turn the player off. Hold in the volume + button and continue to hold it as you re-plug the GoGear back into the computer. After 45 seconds to one minute, Windows will go into recovery mode and resucitate your player.
Also, the number for the Manufacturer - Philips - is
1-866-PHI-LIPS (or was it 1-888? - one of these is an adult line, the other is not) :-)
-Tha Mp3 Doctor
Apr 09, 2006 | Philips GoGear HDD060 MP3 Player
Philips SA3125\02 MP3 Player Logo
48 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
