Question about Whirlpool Ovens
Oven overheats the oven may be set on 100 degrees it cooks as if it was set at 500 degrees
    President:
  • Whirlpool Master
  • 2,651 Answers
Depending on madle you either have a bad themostat, or the newer ovens use an electronic thermistor, not sensing proper temp and shutting off
Posted on Nov 25, 2008
I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
Jan 07, 2017 | GE Ovens
Need to know the cooking time and temp in C in fan forced oven for pork loin roll weighing 1.22kg
usually 40 minutes per 500 grams at 180 degrees C
so 1 and a half hours plus preheat the oven .
And it is thawed not frozen
don't just take my word for it read it on link below
http://www.pork.com.au/home-page-consumer/recipes/cooking-instructions.aspx
Dec 24, 2016 | Ovens
I am usind a rival roaster oven for the first time and their was no instructions in the box and I have never used one before so I am not sure how to go about it.
Hello we were just in a chat session and I told you it would be ok to use foil in the oven but it is not. According to Rival it is not ok because it can make the temp in the oven go over 500 degrees. and the temp in the oven should not go over 500 degrees so you can mess up your oven. Get a cooking bag from the store really quick if you can. Please do not use foil.
Nov 25, 2010 | Ovens
Hi Experts! I'm having problems with my Ariston FO87CIX oven. The oven turns on but if I try to set the temperature the oven turn off and the time resets. It's weird but I've worked out that any...
One of 2 things, either the pt100(sensor) is faulty, or the control is defective. Unfortunately you need a digital multimeter to check the sensor first. When in doubt, replace both and all will be well.
Sep 09, 2010 | Ovens
I have NGC tornado Turbochef, it is toasting too
the subway ovens are supposed to be around 1000 dont change any of the settings if you think you are having programming issues speak to your field rep and ask them to reprogram your oven. they have a smart card for doing this. it will give you all the latest buttons including hashbrowns and breakfast stuff.
most common problem with toasting to dark is that you are using the wrong buttons
try cooking the next sandwich on the 1meat hotwell setting and select the sandwich size. you will notice the sandwich cooks much lighter.
if you cook using the combo subs button this could be your problem. most of the time re-training is just needed
Dec 11, 2009 | TurboChef TORNADO Electric Oven
DOUBLE OVENS COOK 50 DEGREES HIGHER THAN SETTINGS
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case. If the sensor fails the inspection, replace it.
Nov 10, 2009 | Electrolux Ovens
Oven overheating
Set the oven thermostat to 100 degrees ( very low heat) and wait to see if the onen indicator goes off. If it doesn't then the oven thermostat may be faulty. If you have an oven thermometer, then use that to check the oven temperature.
Sep 20, 2009 | Fisher and Paykel AeroTech - OS302M...
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Oven low heat
Did you try going to the GE website to pull up the Use and Care Manual? It does have a section re: how to adjust the temperature by as much as 35 degrees either way. Although it is not the 100 degrees you mentioned, you could try it and see if it helps...
The main GE website is: http://www.geappliances.com/
At the top of the web page is a SEARCH section. You can click on the blue down arrow in the first box and select Use & Care Manuals, then put your model number in the empty box to the right of that selection box, ie. JT952 is my oven.
If you are having a problem locating your model number/serial number, you can go to the FAQ (frequently asked questions) section to see how to find it.
Jul 05, 2008 | GE Profile JT952 Electric Double Oven
Lincoln Impenger 1100
hellow my name is ash i sale linclion ovens and repair they have only one burner and they only go up to 600 degree F make sure that the impenger plates one on top and one bottem are possion prapley, 2nd set temp at 500 and 530 f time 6.5 m if still under cook blow use plates with holes
Apr 27, 2008 | Lincoln Conveyor Oven - 1133-000-A
Ovens Logo
105 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
