Question about Olympus SP-500 UZ Digital Camera
Flash doesnot open by pushing the release button
There is a release button next to the eye piece to activate the flash. That was working perfectly till yesterday. Today, when I push that, there is a little movement in flash, however, the hook does not release the flash. Virtually, I cannot do inddor photography without flash activited. Can any one suggest some remedy to this..??Thanks
  • 154 Answers
First try a GENTLE finger nail to assist the opening - mine got stuck the same and this cured it after i'd cleaned artound the opening mechanism
Posted on Dec 09, 2008
My bosch nexxt 100 series washer will not start. The spin, wash and finish indicator lights flash simultaneously when try to start.
Make sure dial is switched to 'off'. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. If if doesn't work, do it again.
To get the clothes out if you are having trouble, open door manually. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off. The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Click helped if helped.
Mar 07, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
There is a lot of red eye on the photos ,please help.I cannot find a red eye reduction button on the camera.
I don't know whether this camera has red-eye reduction. It is likely to be found in the setup for the flash, or as a toggle for the flash setting. On some cameras, you toggle through the available flash settings until the icon (usually a lightening bolt) has an eye next to it.
Red eye reduction is not perfect even if the camera offers it. You get a much better solution by using a photo editing program in the computer to remove red eye from your shots. Many such programs have a function just for this that works almost automatically. You may have gotten a photo editing program with the camera, but there are many others downloadable for free on the net, try
Nov 03, 2010 | Nikon Coolpix S3000 Digital Camera
How do I setup the homelink feature in my 2000 chevy impala with my garage opener?
First clear it pushing the 2 outer buttons for about 20 seconds till the lite blinks.
Then here is the weird part take the old remote that you use for your garage door opener and hold it next to the home link in the car.
Push the button on your old remote then the button on the home link. the home link will flash slow then quickly (about 10 sec).
Now go push the learn button on the main door unit then back to the car and push the home link again for 2 seconds.
Oct 22, 2009 | Chevrolet Impala Cars & Trucks
Don't have owners manual. I how do I setup the
garage door opener that may be different. But, I believe there are 2 ways to do it. Try pushing the button on the back of your garage door opener by the LED. The light will begin flashing for 30 seconds. During this time, it is accepting new signals. So you have to quickly get in your car and push and hold the button you want to work your door. If the opener accepts the signal, it will flash its floodlight. Then just push the homelink button again to see if it raises/lowers the door.
The second way I don't remember quite so well, but I believe you hold the corresponding button on the homelink until THAT starts flashing, then point your remote at it and push that button. The homelink will flash 3 times quickly if it accepts it. I don't think I've ever gotten this method to work, which is why I'm unsure of the procedure.
I've had new and used cars with and without manuals and the first procedure has always worked. It may take a couple of tries, though
Oct 22, 2009 | 2000 Chevrolet Impala
My camera flash just won't work anymore
Again, the best advice is to immediately contact Canon, and get advice - if you try and fix yourself, it may invalidate the guarantee!
My guess is that when you press the flash release button, to pop it up, an electronic switch powers a release, and a spring loaded action pops up the flash - remember, you have to push it shut after use, it is not auto retract! I also am sure that the charge circuit is activated when the flash pops up. If it is not popping up when you press the button, the charge circuit will not be operating either.
I am sure you will find that if you ring Canon, there is a procedure which will return the camera to default settings, which would reset the flash action too perhaps. It may mention it in the handbook of instructions, or Canon will tell you. I had mine go weird, but it wasn't flash, and they told me, and it fixed my problem when I followed the advice - always ring them, and if you take the advice, and it causes a problem, you have a valid way out of responsibility if they claim you made the problem worse by forcing it to do something it wasn't doing as it should.
Hope this helps
Nov 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Red dye reduction
You can find your manual
You find how to disable red eye function on page no: 63 in that manual.
For quick reference i am giving the details briefly,
The flash modes are as follows:
Automatically fires in low-light and backlight conditions.
This mode significantly reduces
the phenomenon of “red-eye”
by emitting about 10 preflashes
before firing the regular
flash. This mode works the
same as the auto-flash except
for the pre-flashes.
To change between flash modes:
1 Press the (flash) switch.
● The flash pops up.
2 Press the / (flash mode) button
repeatedly until the desired flash mode
indication appears.
● The flash mode changes ,
● If / is not pressed within 2 seconds after the selection screen is
displayed, the selection screen disappears.
● To de-activate the flash (Flash Off mode ), push the flash back into the
3 Press the shutter button halfway.
● When the flash is ready to fire, the
(flash stand-by) mark lights.
4 Press the shutter button all the way.
● The flash fires.
Hope my info solves your problem,
Thanx for using fixya,
Good Luck.
Sep 30, 2008 | Olympus Camedia C-725 Digital Camera
Sony DSC-F828 Faulty Flash
Try resetting the camera. It is next to the battery release. I had a similar issue and posted help. No remedey. So, after praying about this issue, I was lead to power it down and eliminate all the power by taking out the battery push the power button and many others. I found the reset button pushed it and it is all working now. The praying for a solution was key. Praise Jesus. DRD
Aug 08, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Olympus sp 350
There is a "quick" button located on the back of the camera just for flashes. It is the first button to the right of the power button and it looks like a crooked lightning bolt arrow that points down. If you are in any picture taking mode, push this button and it will toggle you through each flash option, auto, red eye (eyeball symbol), flash (same symbol as the button, this mode will make the flash work everytime you take a picture), red eye and flash, and no flash (careful, in this mode you have to allow for the camera to focus, the lens will stay open a long time in a dark atmosphere -- if you don't hold the camera still you will get a blurry picture).
Apr 09, 2008 | Olympus SP-350 Digital Camera
Olympus SP-500 UZ Digital Camera Logo
56 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
