Question about Refrigerators
Water in door will not work
I have not been able to get the water from the dispenser to work. Water does go to the ice maker and that works. It appears like the plastic container which is suppose to cool the water becomes frozen. I have turned the temp down in the frig, but it doesn't seem to help. I was able to get water to cmoe out once, (it was dirty,but did eventually become clean). Once I let it sit though, it stopped working again.
I have pretty much given up on it and now when I push the lever for water to come out, I can't even hear the relay in the back kick in. Thanks for any help.
  • jimbell171 Dec 19, 2008
    I have the same problem with mine and they have come and replaced the door assembly.. worked great for approx 3 weeks and is now frozen again... can hear the relay.. ice maker works great!!! not much room inside this unit... Looks huge but is mostly insulation >>> I guess. Waiting for the repair man to come and lets see electrolux's next brain storm... lol.. still a new fridge think this problem will hit the three problem issue and i will get a replacement..( likely not electrolux)... The newest dishwasher and matching stove work flawlessly.. Very quiet dishwasher....
I have a GE TFX25JPCG and the ice make and dispenser work fine. I was having the issue of the water line located behind the vegetable drawer freezing up and have thawed that several times. Each time that happened I could still hear it trying to dispense when the button was pushed. This time I do not hear it trying to do anything. Would this be a silenoid issue? Or some other issue? If silenoid how do I replace it?
Posted on Oct 19, 2009
  • 33 Answers
I need to know the make and model # to more accurately help you. First and foremost, you will need to thaw your holding tank with a steamer...do NOT use heat gun or hair dryers. The problem could be one of several but I would start by checking the solenoid that supplies the dispenser to see if it is burned out. It is usually located in the back lower part of frig where the water inlet line hooks to. There are usually 2 solenoids.... the ice maker and the dispenser. Unplug the frig before testing these. The resistance across the ice maker and dispenser are usually the same. If the dispenser solenoid is "open" on the ohm meter then the whole water supply valve needs replaced. Another problem with some units where the dispenser is on the FREEZER side...the lines behind the door will freeze. I've seen this with LG's and GE's. They make a special heater modification for units notorious for this latter problem.
Posted on Nov 25, 2008
Water and ice dispenser does not work---the switch clicks when you press it but there is not response, also the ice maker just quit working
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
Aug 10, 2015 | LG LFX25960ST Stainless Steel French Door...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Water dispenser won't work
check the freezer door switch; this is a safety so the ice maker wont come on while the door is open
Oct 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser does not work, ice maker does work. This is a used Whirlpool side by side. I hooked up the water yesterday and the water dispenser worked. Overnight, something went awry and I do not get...
Icemaker is in line with the water and runs from the icemaker threw the door and up to the water valve. So that is why the ice maker is working and the water is not working, most likely the water has frozen inside, And this can be caused by many different reasons, if it has been humid or the door was left open then shut it would cause the moisture in the air to be drawn to the warm water and flash frosted the pipe, try to see if you can defrost the line with a hair dryer. If that does not work post here and I will tell you the next step to try.
Aug 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Refrigerators Logo
420 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
