Empire mod# gwt-35-2 burner will not light periodically
Millivolt generator is making plenty of juice. Limit is not tripped. T-stat is new. Once it fires once it works fine for a while. After it sets for a while it will not fire by itself.
  • Anonymous Dec 03, 2008
    i need a instruccion manual for GWT-35-2 where i can check this.
  • Anonymous Dec 28, 2008
    same problem here. I just moved into a house with two of these. After i got the pilot lights going the both fired up fine but after about a week one stated only lighting occasionaly and now won't light at all. Checked the shut off switch and the pilot light and they seem ok. Any ideas?
    Problem Solver:
  • 7 Answers
I had the same problem when it would not light by itself I could press the sparker and it would light. I stold the limit switch from another one i was not using and put it in and it has not done it since. I think it was just getting weak.
Posted on Dec 09, 2009
  • 27 Answers
Is it the right t-stat. not all t-stats are millivolt compatable.
Posted on Nov 26, 2008
Empire dv-25. Pilot lights fine, good blue flame. Burner rail won't light or stay lit - sometimes it starts to catch. Orifice was removed and was clean - no debris. Not sure where to look next? T.Y.
Do you have an electrical meter that measures millivolts?This sounds like a millivolt system. The pilot orfice and pilot burner need to be clean so they are producing a hot flame, hitting the pilot generator to create enough millivoltage to open the main valve coil. If you know how to jumper the thermostat circuit try it, Millivolt systems will give you problems if there are loose connections or to much resistance through a switch. Again, there could be some type of safety switch that is wired into the thermostat circuit to prevent the heater from coming on if it isn't safe. Call a pro if its not obvious
Jan 01, 2017 | Empire Heating & Cooling
How do the wires from the thermostat connect to the heater? It will not turn on - the pilot light is ON
Sounds like a millivolt system. If it is, there is only two wires that go to the thermostat. There should be two wires to connect the thermostat wires either down by the valve or on top of the furnace. Make sure the valve is turned to "on" and not just "pilot"
Apr 11, 2011 | Empire GWT-50 Wall Mounted Panel Heater
My empire wall furnace does not ignite. It has gas flowing because the pilot is light, i have changed the thermostat and wired it two different ways in case I reversed them. What is next? Could it be the...
It could be several things: Is the Control Knob turned from Pilot to ON? If that is the case, wait a few minutes after turning it to ON. That will allow the Thermopile to heat up sufficiently. Be sure the flame is touching the Thermopile. If everything looks correct turn up your Thermostat to higher than the ambient room temperature and see if the burners light. Remember to turn your Wall Thermostat down to the lowest temperature setting before turning the knob from Pilot to ON.
FYI - That Wall Furnace does not have a Thermocouple. It uses a Thermopile instead to generate millivolts of electricity to open the gas valve and maintain the pilot flame.
If it is the Thermopile, you can order it directly from Empire Comfort Systems, as well as download your Owners Manual at www.empirecomfort.com
Feb 04, 2011 | Empire GWT-50 Wall Mounted Panel Heater
My dv-215 direct vent propane unit thermostat is no working right. The burner will not lite until I push down on the mechanism inside the thermostat the burner will shut off when I move the mechanism to...
You need to replace the thermostat if you have to force the contacts to close.
Make sure you get the right type of stat. It appears this is a thermopile millivolt type, as opposed to a standard thermocouple. The stats are not interchangeable.
I noted stats were available at Sears, but there I am sure there are other sources to purchase from.
Dec 18, 2009 | Empire DV-215 Direct Vent Natural Gas...
Empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
Pilot won't stay lit
Your unit has a "vent safety limit switch" which is a high temperature limit. It gets hot enough to trip over time because you do not have proper venting. It is a safety switch and SHOULD NOT be disabled - instead find and fix the venting problem(chimney bad?)!
Mar 27, 2009 | Empire GWT-50 Wall Mounted Panel Heater
Comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Nov 29, 2008 | Imperial IFS50 Deep Fryer
Pilot will light, burner will not light.
check all limit switches to see if they can be reset if so reset it ,if problem reoccurs wich limit is going out ? make sure all wires are connected well to your gas valve , use a low voltage tester to make sure your firing circuit is operating properly , if you have a thermocouple it may not have enough juice left to open your gas valve
Nov 02, 2008 | Empire DV-215 Direct Vent Natural Gas...
Pilot on burners won't light
Pilot won't light - natural gas or propane. check for a spider web in the burner tube. check no dust in burner tube. check surface igniter is lit. if pilot lights check flame detector - may be a millivolt generator - it is a small capillary with a copper tip in flame path. no fire will keep the pilot valve closed. replace the generator.
Jan 29, 2008 | Heating & Cooling
Heating & Cooling Logo
384 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
