Question about Panasonic Toughbook 17 PC Notebook
Wet screen panasonic toughbook
Windex leaked on to the computer and now the screen is wet, is it repairable?
    Problem Solver:
  • 5 Answers
If you couldn't just wipe off the liquid, there are two possible places it could be hiding: If you have an aftermarket screen protector, some might've gotten under it. Try with your fingernail to lift the edge of the screen surface. If that doesn't do the trick, it's probably between the touchscreen digitizer and the display panel. Opening the screen is easy. You'll need a #1 Phillips screwdriver and about twenty minutes. Identify the hinge cover, a single piece of formed sheet metal that runs along the top of the keyboard above the F-keys, and curves around the hinges to the back of the machine. Start with the laptop closed, standing nose-down so the handle is in the air. Remove the two screws securing the hinge cover to the chassis next to the handle. Then set the laptop down in its normal orientation, open the display 180 degrees, and remove the other three screws from the hinge cover. The hinge cover should now lift free. Set it aside. Now, remove the ten screws around the perimeter of the screen. You'll need to pry out the rubber bumpers to get at two of them. Once all ten are out, raise the screen to the 90-degree position and gently separate the cover from the frame. At this point, the back of the display panel should be visible, along with the flex cable that leads into the main cabinet, the backlight inverter, the touchscreen control board, and the wireless antenna, if equipped. Identify the connector where the clear four-conductor flex cable from the touchscreen meets the control board. Gently pull the beige latch lever away from the connector and remove the flex cable. Do this with the other flex cable connectors, too. Now you should be able to separate the display panel itself from the frame. I believe it's just held in by rubber bumpers, though there might be a few screws too. (It's been years since I had my display apart.) Once you have the display out, any liquid between it and the digitizer surface (which is bonded to the frame/bezel) should be easy to remove. Installation is the reverse of removal. Observe static precautions, and work in the most dust-free environment possible. Any speck trapped between the digitizer and display during reassembly will drive you nuts!
Posted on Jun 13, 2007
  • 4 Answers
I have had some luck with just letting things dry out for instance dropped cell phone in water completly submerged I shook what I could out of it sat it on my dashboard in van (after taking battery out) waited about a week cut it on and it worked like a champ Electronics are funny things This is something you could try depending on how fast you need it back you dont have to put it on dash just somewhere near heater may work or may not but worth a shot has worked for me in the past.
Posted on Jan 02, 2007
  • 624 Answers
I didn?t understand exactly what was going on with your LCD monitor, however, if the Windex leaked into the monitor and it no longer works then the answer is probably but depending on what is damaged it may not be economical to do so. If the Windex just leaked into the laptop and it still works then you?ve been luckily. In either case the thing to do is disconnect it from the A/C power source and remove the battery to prevent further damage. You or a repair shop needs to disassemble the appropriate components and remove any remaining liquid immediately.
  • tomj23 Jan 03, 2007
    The problem with letting things dry out is that they deposit whatever material they had in suspension. Clean Windex by itself isn't too bad but the problem with letting things dry naturally is that you never really know if its all dry and Windex, water and soda are excellent conductors.
    At the very least you need to put the device in a hot box of some sort where the temperature is sure to warm up the device and evaporate the liquid.
SOURCE:
How would I repair the screen of a Panasonic toughbook cf-30?
I think you will find the cost of the screen approaches the cost of the tablet and then the time to replace and the skill involved really are not worth it.
Dec 23, 2016 | Panasonic Computers & Internet
Print screen not working panasonic toughbook
On any Panasonic Toughbook: The PrtSc or Print Screen key will not print the screen directly. The trick is to use "Shift" + "PrtSc" which will then "capture" an image of the screen.
Then you open the Paint program and then with the cursor in the middle of the blank screen you press the "Paste" button. This will cause the image that you just captured to be displayed in the Paint program. You can now save this image as a BMP or as a JPG image. It can now also be printed.
Good Luck.
Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Feb 14, 2014 | Panasonic Toughbook CF-51 Notebook
How to screen shot
On any computer including Panasonic Toughbooks,
to capture the image currently on the screen, please
press "SHIFT" + "PRTSC".
PRTSC= Print Screen
The to see the captured image,open PAINT under Accesories
and then press the "PASTE" button. This will copy the image
stored in the clipboard to the screen.
Finally, save the image either as a JPG or a BMP and
voila this is now a picture file that you can use in the future.
Good Luck.
Richard from Montreal
Authorized Panasonic Toughbook Dealer since 1989.
Feb 06, 2014 | Panasonic Toughbook Computers & Internet
How do i enable touchscreen on panasonic toughbook cf 30ctqazbm
The first thing I would try on any Panasonic Toughbook with touchscreen would be to enter the BIOS upon start-up by pressing the "F2" function key. When you are in the BIOS, there is a setting on the 2nd screen tab "Main" which says "Touchscreen:". This should be set to "Enable" instead of Disable. Then you press the "F10" function key and the message: "Save configuration changes and exit now?". Press "Yes" and the toughbook will reboot and your Touchscreen will be enabled at the BIOS level.
Good Luck!
Regards from Richard, Montreal based Panasonic Canada Authorized Toughbook Dealer since 1989.
Dec 27, 2012 | Panasonic Toughbook CF-30 Notebook
Panasonic Toughbook 28 PC Notebook CF-51RCVDNBE
All drivers for either the Toughbook 28 or the Toughbook 51
can be found on the following Panasonic Official Website:
Official Support Download Center of the Drivers Manuals and FAQs TOUGHBOOK...
Good Luck to you and Regards from:
Richard, Montreal Based Panasonic Canada Toughbook
Authorized Dealer since 1989.
Jul 20, 2012 | Panasonic Toughbook 28 Notebook
I have a CF-30 toughbook and my screen lights up for about 4 seconds and then goes dark everytime I open the the lid. I can see the screen is still on but not lit up, it will relight if I close the screen...
It could be loose wiring.
1. Take the screen bezel and LCD board off and reseat all the connections. In other words, unplug and plug it in again.
How to: CF-30 toughbook LCD replacement video
2. If that doesn't solve the problem, then you must replace the LCD inverter.
Best Regards,
Embraced Support
Fort Lauderdale Computer repair
Sep 05, 2011 | Panasonic Toughbook 30 Laptop
Panasonic toughbook cf 18
You will, at the very least, need to have the screen and screen cover replaced. If the hinges also damaged the bottom case to which they are attached, then it too will need replacing.
If you can't get it repaired locally, let me know.
Jan 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toughbook LCD is Dark.
On all Panasonic Toughbooks, any model pre-2008/2009 would have the older LCD screen with an "inverter". The new screens are called LED because there is no inverter.
The inverter is like the "ballast" on a fluorescent tube lighting fixture. The tube could be good but if the ballast is blown then the tube will not "light-up". This is also true of the inverter.
You can also tell when the inverter is about to burn-out when you first start your toughbook in the morning and the screen is initially "red" and then turns white after the unit warms-up for a few minutes.
Good Luck to you.
Regards from Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Jul 10, 2017 | Panasonic Toughbook 28 Notebook
I have a panasonic toughbook notebook model cf 18 I recently had major repairs done to this and now I can not get the sound or touch screen to work I am currently running windows xp on this computer
It sounds like the cables for the sound & touchpad were not fully connected. Take it back to the servicer and ask them to reconnect your audio & touchpad cables.
Dec 23, 2008 | Panasonic Toughbook CF-73 Notebook
Panasonic cf-51 laptop from iraq
I'm sorry Joel, these screens are considered sealed units, and you can't get replacement parts for them. You'll have to purchase an entire screen. Give your brother my regaurds, Semper Fi !!!!
Aug 05, 2008 | Panasonic Toughbook 51 Notebook
Panasonic Toughbook 17 PC Notebook Logo
373 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
