Question about GE Wireless Optical Mini Mouse 3087897985
Not working Do i need to insert a battery?
    Sergeant:
    Champion:
  • 274 Answers
If it's a wireless mouse, yes, it needs a battery. Also, once it's powered on, press the button under it to sync with computer/receiver.
Posted on Nov 25, 2008
Aspire 2225g works only without battery
You need to replace the battery. A lot of laptops will work from AC adapter when the battery is out but when the battery is installed they default to battery and the AC adapter defaults to charging. When the battery is bad you get the results you describe. If for some reason it did the same thing with a new battery then the power circuit would need to be replaced, but this is not typically the case. Almost every time I have fixed someones Laptop with the problem you describe, a new battery was the solution.
Mar 17, 2014 | Acer Aspire Computers & Internet
Sony ericsson w995 won't charge. On attempting to charge phone says "Battery can not be charged insert a Sony Battery" (the battery is the original battery) once that screen goes it says insert SIM even...
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 16, 2010 | Sony Ericsson Walkman® W995 Cell Phone
My blitz keeps saying insert the battery when it already installe
the batteries dead. you need a new one because after the battery dies it wont awknowledge the charger or battery. same thing happened to me. honestly this phone is a piece of ****. youre gonna have a lot more problems ttrust me. im having a problem with it now.
Jun 30, 2010 | UTStarcom Blitz Cell Phone
Had not used our mouse in quite awhile, put in new battery but still is not working
If its the 3000 ... you need to snap the battery compartment in correctly to get the battery to work.
Replace the battery. When you reclose the battery compartment you just snap it in place but be carefull.. even though its easier to insert the top and then slide the bottom down in DO THE REVERSE... insert the bottom prong allllll the way in and then snap the top forward and into pace. In order for the battery to work the top needs to be firmly in place and I've found that snapping it in in the aforementioned way is the only way to make sure its snug n stuff.
Hope that helps. I've had this mouse for five years and love it but alllways forget that issue in replacing the battery and inevitably spend fifteen minutes scratchin ma head everytime the battery needs replacement.
Feb 25, 2010 | Microsoft Wireless Notebook Optical Mouse...
My daughters ds lite only works properly with no game inserted and the charge light doesnt come on. if it does work with a game inserted it then turns itself off after a couple of mins.
sounds like a faulty battery, try to get hold of another battery and try it. If that dosent work it could be fuses on the logic board have blown, worst case you need a new logic board.
Jan 09, 2010 | Nintendo DS Console
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Computer will not charge or power up is their some type of reset button? The unit Model NBQ115-TS05/TS09
tried to remove battery and ac for a little while?
if that doesnt work, remove battery and ac-power.
remove the ram
put ac-power back and try to boot without ram
(do you get a beep/error?)
remove the ac again
insert the ram
insert battery
insert ac
try to boot up again.
if that doesnt work its probably a mainboard error and you need to take the computer to repair.
May 29, 2009 | Computers & Internet
Will not power up, no lights or sound
remove the ram
remove the ac again
insert the ram
insert battery
insert ac
May 29, 2009 | Intel Everex LM7WE Notebook
No power/battery won't charge.
try inserting another with the same type of battery, that you can assure that is a good battery. Insert it with your phone then observe! If the same happens with your own battery, then the problem is im sure with your phone, then you need now for a proffesional help by going to cellphone repair shop. But if it will on and it will charge if you insert the new battery, then the problem is with your battery itself. You should purchase with a new battery. Is this solution helful to you? Then you ca send me email at st_nardz@yahoo.com for my further assistance. kindly rate this solution. thank you...
nardz
Oct 27, 2008 | Nokia 6101 Cellular Phone
I have a Timex Ironman Triathlon Speed + Distance...
The Timex Ironman manual and website says to take the watch to a repair facility. Nope! Do it yourself!
How to replace the battery in a Timex Ironman watch:
This is easier if you remove one of the rubbery wrist bands.
1. Take note of the position of the metal back cover. You'll need to reinstall it exactly as you see it in order to hear the alarm.
2. Remove the four screws that hold the metal back cover, and pry off the cover.
3. There is a round metal clip that holds the battery in place, covered with a transparent plastic cover which likely says, "Unlatch to remove battery". Within the center of each clip, there's a small opening just large enough for a straight pin to be inserted. A jewelers screwdrive won't work - use a straight pin. Insert a straight pin into the tiny opening at the edge of the clip, and wiggle it. The clip should release. You'll only need to unlatch one side of the battery retaining ring.
4. Gently pry up the batter retaining clip, then pry up the battery. Insert new battery.
5. Replace the clip.
6. Insert a flat blade screwdriver into a slot which has two "electrodes" or pins - they need to be shorted with the screwdriver to reset the watch. Just touch the screwdriver blade across the two pins to short it.
7. Reinstall the back cover but be sure to position the cover so the alarm sounding place ( a small disc attached to the inside back cover) will reside over the sounding spring.
8. Insert screws.
Dave
Oct 01, 2007 | Timex Sports Ironman Triathlon 100-Lap...
Computers & Internet Logo
48 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
