Question about Viking VGIC305-4B Gas Kitchen Range
Viking stove I have a viking gas range and the brioler does not work but the oven does would that be the themostat???
    Habit-Forming:
  • 171 Answers
No the termostat but the ignitor that's the part that's nest to the broiler burner. the part that ignite the flame. when you turn on the broiler the ignitor becomes red like a glow.
Posted on Dec 10, 2008
When i trun on my stove the brioler does not go on
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 15, 2011 | Kitchen Ranges
We have gas (we can smell it) on our Viking range and oven, However, the oven, oven lights and the burners are not working. Is this an electrical problem or what do we do to fix it. Thanks.
Can the gas company immediately if you are smelling gas in the home. Also locate the shut off valve, which is most likely behind the stove.
Jan 20, 2010 | Kitchen Ranges
VIKING STOVE DOOR IS LOCKED AND WILL NOT OPEN , STOVE WAS IN A SELF CLEANING MODE AND DOOR WON'T OPEN AFTER CYCLE COMPLETE
unplug or turn off breaker to stove for 10 minutes...then try to gently open.....the oven has to be completely cool before it will unlock....when cleaning is done release lock before turning cleaning off
Nov 28, 2009 | Viking VGSC306-4B Gas Kitchen Range
Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
Dec 20, 2008 | GE JGBP33SEHSS Stainless Steel Gas Kitchen...
Viking oven
We had a hurricane come through and power was out at our house for 2 weeks. The top burners worked but the oven would not. Our outside gas grill worked perfectly also using the utility provided natural gas. We were told by Viking that the oven is designed to work only when there is electric power. This is a safety feature, according to Viking.
Sep 22, 2008 | Viking VGSC306-4B Gas Kitchen Range
Viking VGIC305-4B Gas Kitchen Range Logo
608 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
