Question about LG LRE30755 Electric Kitchen Range
''Start'' keypad won't work
Help. My "Start" keypad won't work. Any suggestions?
  • Anonymous Apr 19, 2009
    Oven temperature key pad will not work for 6,7,8 or 9.
  • 32 Answers
Sounds like there's a problem with the touchpad.
Posted on Dec 23, 2008
I just replaced the circuit board for the clock and oven on a GE Range. When I plug it in, the error code is F 760
Hello. From what you describe, the error code is for a defective keypad. I need the model number to help you accurately. Depending on the model, the main board can either have the buttons mounted on it as one unit or, the keypad can be a separate panel, connected to the main board by means of a wiring harness(with a multi-pin connector) or a ribbon cable with a connector(s). Keypads become shorted commonly--it's like you're continuously pressing a button and won't let go. The main board senses this and because of safety built into the control program, stops and gives an error code. Nothing will work until you let go of the button. They fail a lot due to heat from the rear burners and/or the plastic becoming brittle. I hope I helped you!
Sep 14, 2015 | GE Kitchen Ranges
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
I am getting E0 -F2- error on my Whirlpool Gold Accubake oven display. If I press cancel it sometimes will start but has been working less and less. The range is quite old and I do not have a manual. What...
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Mar 29, 2011 | Whirlpool Accubake RF362LXTT Electric...
Oven controls not responding to pressure. Stove top ignition works, oven light works. Clock view has been turned off for years, so clock display is not a diagnostic. What's to do?
Sorry to read about your problem, I hope this helps you out.
you have either a defective keypad or logic board. I suggest you contact a service company
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Amana AGS1740BDW / AGS1740BDQ / AGS1740BDB...
Display shows E0 F2 after pressing start and cancel at same time. No other buttons work. Stovetop still works.
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 14, 2010 | Whirlpool GY398LXPS Electric Kitchen Range
My oven display says EO F2 and nothing works! I'm worried as there's a bit of a haze in the house after a day like this
Straight from the manual. Try unplugging the machine from the mains for about 5 mins. Then reconnect, now see if that fixes things.
http://www.repairclinic.com/Range-Stove-Oven-Repair-Help
DIY help.
http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#electric
Apr 17, 2010 | Whirlpool Kitchen Ranges
Hi, this error code indicates a shorted key on the touch pad.
1. Check keypad connector for firm connection also clean with a pencil eraser (keypad connects to control board).
I you have any other questions please feel free to ask. Mike
Mar 25, 2010 | Whirlpool GY398LXPS Electric Kitchen Range
Hi, I am getting an error reading on my whirpool gold stove it reads EO -F2- do you have any clues to what my be my problem. Thank you in advance for your suggestion
Sep 20, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Kitchen Aid KESA907 Error F2E0 Stuck Key
Turn off the breaker and wait for 5 minutes. the follow these steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Apr 24, 2008 | Whirlpool GERC4110PS Kitchen Range
Stove question
According to the service sheet E2F3 error code means keypad spill. Solution: clean keypad.  The solution suggested did not work for me. I also sometimes get the E2F1 error code in which the service sheet suggests that the cancel key is invalid. Solution: clean surface.  I think that either my key pad is shorted or that there is a malfunction of the power board. In either case $$$
Oct 18, 2007 | KitchenAid KGST307 Gas Kitchen Range
LG LRE30755 Electric Kitchen Range Logo
231 people viewed this question
Top LG Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
