Question about Philips 50P8341 50" Rear Projection Television
Philips Projection Screen TV Model PTV915 Horizontal Alignment
Hello everyone,
I have a Philips Projection Screen TV Model PTV915 with Horizontal Alignment issues. (for some reason this forum system does not recognize the model)
The RED is not aligned and I do not know where the focusing controls are on this unit.
I opened the unit up and tried to work the RGB focus dials and I have focused them to appear sharp and clear but the I see 2 distinct lines of text each within the color space.
You can see The text frozen on the screen and a red layer of text floating just above it to make it appear as a red duplicate behind it.
How do I align them? I assume there must be some sort of control within the unit. I have already tried to use the RGB focus dials but it is does not align them.
Any help you can provide would be much appreciated.
Robert  Bloomingburg, NY
  • Edward
    Edward May 11, 2010
    You have a problem with your convergence circuit. Most likely the convergence IC's and resistors need to be replaced.
Problem solved, needed to get the universal remote i was using set up with the proper code. Once I did that I was able to use the remote to set up the single & multi-zone Red & Blue Alignment.  I also pulled the back plate off and manually adjusted the RGB focus knobs. It seems to be working just fine now.
Thanks to all the other posts.
Posted on Dec 01, 2008
I was given a big screen Magnavox TV model #38346033. I don't know how to clean the screen. Also the screen has red, green and blue that needs to converge and I don't know how. I don't have the remote or...
Hello linda, hi, I dont think the remote or manual can help the color issue problem, the tv needs to be looked at by a qualified technician. If the TV is a tube type, there are magnets on the neck that needs alignment, this alignment is done while the TV is ON. so high voltage risk are likely. keep out and call service.
Jun 15, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
I need the code for ptv915
Service & Alignment mode enter: 062596+Index or Status
Digital Convergence mode enter:062597+Index or Status
HBSkirmit
Mar 02, 2009 | Philips Magnavox 27MS343S 27" TV
Philips model projection
hello dm beatty, First i must ask if you have anything placed on top of the tv? second what i would suggest is for a professional repairman to come and fix it. There are proceedures which you may do it yourself but if you were to mess up it would cost you a new tv. If you would like more assistance to do it yourself place post again and i will be happy to assist.
Please post what you do and how you did it. I look forward to your posts.
Nov 02, 2008 | Philips 50P8341 50" Rear Projection...
Philips Proyection-60P8341 from the PTV915 series
those models are famous for the LSB boards going bad and they are hard to track down the cause if the LED isnt blinking. You can get a repalcement LSB for your model at the following link. Leave them a email and they may make you a good deal on one. Heres the link.
http://servicemanuals.vstore.ca/
Sep 30, 2008 | Philips 60P8341 60" Rear Projection...
Philips 50p8341 chassis PTV915
Well the manual seems ok ,but you need check the board as there burn out in it which causing this problem check the IC S and the tracks on the board ,even bad connectors can cause this problem...
Good luck...
Sep 09, 2008 | Philips 50P8341 50" Rear Projection...
Need help
does the light blink? if so how many times?
Jan 22, 2008 | Philips 50P8341 50" Rear Projection...
Philips model ptv915 model # 60P8341a
  • sound  off & on is dye to loose contact in sound section
  •  plz check
  • speaker wire or connector loose.
  • speaker defective.
  • loose contact or print loose in sound section.
  • supply to sound section.
  • sound output ic or print loose.
  • hopr this will help
  • good luck.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
I have projection TV 55PP9363H/17 SOUND NO PICTURE.
check the horizontal output transistor, it could be open.
Jun 19, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
602 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
