Question about Asko T701 Electric Dryer
CAN'T FIND INTERNAL FUSE TO REPLACE IT
ASKO T701 DRYER
  • Anonymous Feb 05, 2009
    Same problem. THere are two 15A fuses as the first person to post said, and one of them seems to be in really bad shape. Going to replace it today if I can find a replacement fuse.
There are two 15a fuses on the back right top. Mine have a grey flathead cover that you twist 1/4 turn to remove.
Posted on Jan 24, 2009
    Genius:
  • 1,198 Answers
I've never seen a fuse in an electric dryer, you could have another problem. List your symptoms and the voltage of the dryer.
Posted on Nov 25, 2008
2 Suggested Answers
jnchahn
  • 252 Answers
SOURCE: asko t701 dryer won't start
If yourdryer is not starting then it is your motor. To determine this there is a trick you can try. First, put a piece a tape over the safetyswitch on the dryer. Take one hand andspin your drum of your dryer as your press the start button. If it takes off, then there is a bad spot onthe motor. Another thing is to try checkto see if you are getting 220 Volts to you outlet by taking a volt meter set at250 volts. Take the red leg of the voltmeter to the one side and the black leg to the other side. If the volt reader reads 220 then you aregetting the proper voltage. Finally, ifyou are getting 220 volts then it is your dryer heating elements. On a 220 volt for the dryer one leg is forthe motor and leg is for the element.
Posted on May 11, 2011
What does the code C3 mean on my Asko Dryer
Asko electric dryer model T701 has timer-controlled drying in addition to the two automatic (thermostat-controlled) programs. Without electronic, there isn't possible display fault code.
Dado
Sep 26, 2014 | Asko T701 Electric Dryer
Asko t701 dryer won't start
May 11, 2011 | Asko T701 Electric Dryer
We have an ASKOT701 electric dryer with a broken belt. Can we replace this ourselves?
you may be better getting asko to replace it,they can be difficult to get back together
Jun 05, 2010 | Asko T701 Electric Dryer
Need to replace the belt on the asko t701 what is the difficulty level doyou have a diagram
NO DIFFICULTY- PUT THE BELT ON THE SMALL PULLY FIRST IN THE GROOVES AND ROLL THE LARGE PULLY AROUND A COUPLE OF TIMES TO POSITION THE BELT
Oct 04, 2009 | Asko T701 Electric Dryer
My Asko dryer shut off and my clothes are still wet. It won't start and the light on the pannel will not come on. I know I probably have lint in the system that escaped the lint trap or maybe something...
YOUR DRYER Has a fuse in it look for it probably somewhere close to where the main power comes in at. if it's good check the heat relay contactor assembly. www.repairclinic.com has the model you have and it may even be as simple as the door switch
Apr 09, 2009 | Asko T701 Electric Dryer
T700 Dryer Won't heat
not turning off, is caused by a small stepper motor attached to the back of the timer, that actually moves the timer (if a mechanical knob, my memory for obscure (sorry) models isnt perfect) they fail and are replaceable, separately to the timer, or the timer can be replaced with a rebuilt one, at approx the same cost as buying a stepper motor,
No heat is caused by the failure of a thermal cutout(thermal fuse overtemp cutout or any of a dozen other names) a small device like this 5850e1d.jpg or this 4947033.jpg screwed on the ducting between the fan housing and the exhaust, with wires to the terminals.
when you stopped the unit while it was very hot, heat built up enough that the thermal cutout melted. test with ohmmeter or bulb and battery, no conduct -replace
Notes
There are only a few cutouts common to most dryer models the local parts guy will have one to fit, even if marked with a different brand name,
generic compatible timer available at local parts guy
saving a 100mile drive
Sep 09, 2008 | Asko T701 Electric Dryer
Asko T701 Runs for full cycle but does not dry
thermal cuttouts(thermal fuse or half a dozen other names for the same thing) on the exhaust duct look like this 088c0f1.jpg or this 89f91e6.jpg, the high temp one is blown.
locate and test with ohmmeter or bulb and battery
replace, not a repairable item, but inexpensive,
there are very few cutouts common to many dryer models
the local parts guy will have one to suit even if marked frigidaire or ge
while the dryer is open is a good time to de-lint the fan and exhaust ducting to the outside wall to prevent recurrence
Jun 25, 2008 | Asko T701 Electric Dryer
Asko T701 electric dryer
Check the two fuses on the back. I had one burn out on me. Also there is a reset button on the back in the very centre (it is a rubber button).
Apr 18, 2008 | Asko T701 Electric Dryer
Asko T701 Electric Dryer Logo
320 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Asko Dryer Expert? Answer questions, earn points and help others
