Question about Coleman Powermate 60 Gallon Air Compressor
Wires on Compressor motor disconnected.
Hi, I just receieved a used coleman 6.5 hp 60 gal air compressor. Model number C65C600V1B103. There appears to be a part missing. perturding from the top of the motor are four wires with female conntectors. The two on the right are white and black and the two on the left are blue and black.
I cannot seem to find a manual for the compressor. Any ideas??
Jeff Mohler
  • mohlers2 Nov 25, 2008
    Thank you.
    I was given this by a friend. It seems that there are no capacitors on the motor. It is a magnetec, part 8-182852-nu
  • 65 Answers
Some compressors come unwired so the purchaser can wire for 110 or 220 by their choice. This I would think would be possibly your case. Was this purchased new? In any case, here is a site where you may be able to obtain a manual,
and here is one with a similiar description but a different brand compressor.
hope this helps. copy and paste short cut, in case you may not know, highlight text you want to copy by holding down left mouse button and moving pointer of mouse over text desired,while cursor is still over the high lighted area release left button and right click mouse, select copy, then put cursor in the box you want to paste, right click and select paste
Posted on Nov 25, 2008
I have a 33 gal craftsman compressor when I turn on the relay switch hums but the motor doesn't spin?
I would check the capacitor since it appears that the motor is not locked up. Here is a how to on testing capacitors;
May 16, 2012 | Craftsman 33 gal Air Compressor 6 hp...
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Hello...I have a blackmax 60 gallon 6 hp compressor. Model # BL6006016. Twin cylinder, single stage. What kind of oil do I use ? Thank you!
Compressor oil is less demanding then cars, but car oil works fine. Normal 1W-40 would probably work the best.
You would hardly ever have to change it either, because there is no water, soot, or acids produced in a compressor, as there are with a car.
Feb 26, 2011 | Coleman Powermate 60 Gallon Air Compressor
How do I wire my 60 gal 3 hp IR commpressor? What size wire, what size breakers, and where on the motor do I attach my wires. Motor says 15 amp, 220 volt. Thanks, Clint
I would use a # 10 wire size with a 30 amp breaker. The motor should already wired to the pressure switch unless it has a mag starter. If no mag starter incoming power should go to pressure switch not motor. If unit has a mag starter incoming power should go to top of mag starter.
Jan 12, 2011 | Ingersoll Rand Single Stage Cast Iron 3 Hp...
I have a Coalman Powermate 6.5 Hp 60 gal. compressor model C650C600VIB103. I want to know to connect the elect. cord correctly.
Does the unit have a starter or just a pressure switch , if just a pressure switch it should be marked with line and motor , the wires on the motor should go to the motor terminal and the line terminals are the power supply , if the unit is 110 volts make sure you put the wires on by color , the white wire goes to the motors white wire and the black to the motors black wire , if this is 220 volts it does not matter which wire connects just put the two black wires on the line terminals. One wire per terminals please.
Jul 17, 2009 | Coleman Powermate 60 Gallon Air Compressor
Sparking brushes
try blowing out motor i have used a armature cleaner like acetone while motor is unplugged or just replace brushes
Jun 26, 2009 | Coleman Powermate 60 Gallon Air Compressor
Coleman Powermate Model Number BV6548049, pressure switch leak.
Usually, a leak at the pressure switch unloader valve is caused by the checkvalve in the tank. The unloader valve at the pressure switch bleeds out the air from discharge tube after compressor reaches set pressure. This only takes a few seconds. If air continues to leak then air is leaking back into the discharge tube past the tank checkvalve. Follow the air discharge line from the compressor to the brass valve at the tank. The brass valve is the checkvalve that holds the pressure in the tank. There are usually two connections at this valve. One is the unloader tube to the pressure switch. Simple test for leaking checkvalve, with pressure in tank unplug or switch off the compressor and remove the small unloader line at the checkvalve(brass valve) and look/listen for leak. If leaking, remove the checkvalve and examine seat/check for debris keeping the valve slightly open. If it cannot be cleaned, order generic replacement from It will cost less than the factory checkvalve. Just pay attention to the thread sizes for easy fit. Good Luck on your repair and email if you have questions.
Mar 25, 2009 | Coleman Powermate 60 Gallon Air Compressor
Coleman Powermate 60 Gallon Air Compressor Logo
598 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
