Cars & Trucks Logo
jeff holland Posted on May 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't start 2002 Chev Venture won't start. When you turn the key nothing happens. The battery has plenty of power but nothing happens when you turn the key. What could be the problem?
Anonymous
Level 3:
Brigadier General:
  • Master 6,468 Answers
  • Posted on May 24, 2012
Anonymous
Master
Level 3:
Brigadier General:
Answers
6468
Questions
0
Helped
2131765
Points
13357
Could be the neutral switch try and crank it while moving the shifter around also try and put power to the small terminal on the starter that will tell you if the starter is bad or the wiring or switches
5 Related Answers
Anonymous
  • 116 Answers
  • Posted on Jun 06, 2011
SOURCE: 2007 chevy cobalt ls won't
Ignition relay or fuse could be the problem. When you turn the key to start do you hear a fuel pump kicking on and or do you have spark when you hot wire the starter (I know it's hard to check while trying to start it)? You can email me back and I might be able to pinpoint it more.
Anonymous
  • 206 Answers
  • Posted on Mar 14, 2009
SOURCE: replaced battery securty light came on power no start
Here is something that the emission wiz helped me with
PASS LOCK RESET GM CARS 1999 UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the passlock system to recognize your key
Anonymous
  • 38 Answers
  • Posted on Mar 19, 2009
SOURCE: 2003 chev venture i turn the key and nothing no
Most likely your starter or the starter solenoid. (assuming your battery isn't just really low...)
RamTek
Ramy de Jesus
  • 377 Answers
  • Posted on Jan 11, 2010
SOURCE: my catera wont start. I turn the key and have
Check the starter maybe needs to be replace and check the carbon of the starter.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Anonymous
  • 1206 Answers
  • Posted on Jan 27, 2010
SOURCE: My keys are locked inside my 2000 chevrolet venture, Is
call onstar!!! just kidding no! the only way now is to use a slim jim(door opening tool) most auto parts sell them for 5 dollars or so unless you have AAA auto club card or know a member they will come out and do it for free sometimes police officers can also help you. hope this helps you.
2002 silverado 1500 hd won't start
When you turn the key to start does the starter engage an spin the engine ? or nothing happens .
the lights and music come on but the motor will not start when I turn the key ??????? Will not start how ?
crank - no - start or no crank no start . ????????
Car won't start, seems to have power, all lights working. when I turn the key nothing happens. this only happens sometimes
Could be a bad alternator.. It may not be holding charge. Or your starter could have failed.
Though I've had the same problem and it was a dead battery in my vehicle. Had enough power, but to keep the car on..
2answers
Won't start
How about corroded battery cables (internal)
Fusible Link wiring corroded & open circuit,does
everything electrical work except the starting circuit?
Turn key & have power to starter solenoid ?
Neutral Switch !
Ignition Switch !
Tough to guess without wiring diagrams,
to see where to start testing
Can't fix what you don't know you have
Replaced transmission in my 2003 Chevy Venture and now it won't start.
can you manually shift the neutral safety switch while connected and test it in all positions to see which position lights the ignition side?
2007 chevy cobalt ls won't start battery good starter good turn key nothing no click nothing all lites work on dash and radio works jumped starter with screwdriver turns. Over but won't start...
1helpful
2answers
2003 chev venture i turn the key and nothing no sound at all i have radio and lights and power windows work any ideas
Duplicated key wont start engine
Their is a computer chip imbedded into the original key. Take it to a real locksmith and most are able to make another coded key.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
