Question about Snom 300 IP Phone
My snom 300 is dialling letters instead of numbers how do I fix
Snom 300 is dialling letters instead of numbers
how do i change back
  • 1 more comment
  • ognews Dec 02, 2008
    Thank you so much !
  • Anonymous Mar 12, 2014
    unable to register snom 300
  • Anonymous Mar 26, 2014
    i forget pin lock snom 300 how can unlock this pin
  • 4 Answers
Pick up the handset and press down on the direction button until the display reads "123" instead of "ABC" or "abc"
Oloff
Posted on Oct 22, 2009
Press one of the dial keys > you'll get a letter printed on your screen > than press the down key and you'll see on the bottom right side of the screen the change form "ABC" to "abc" to "123" ori www.tourwise.co.il
Posted on Jun 04, 2009
Press 1st key(out of 4) on left side, (right under the phone display) until number appears - like u will do it on your mobile.
Posted on Apr 29, 2010
No upward !!!
downward.
Posted on Jan 25, 2009
Change the mode, as u change in ur mobile phone while typing the SMS.
Press the arrow key in upward direction and u willl see the change on the screen.
At the upper side of the screen u will see '123' .
Posted on Dec 02, 2008
How to fix snom 300 because it cannot received calls
Is your phone connecting to a hosted PBX provider or is it connecting to a premise-based IP PBX? Incoming and outgoing calls are usually handled by two separate connections between your PBX and the service provider SIP trunk. Sounds like a registration problem with the SIP trunk. There is nothing you can do from the phone itself to fix this.
Nov 16, 2014 | Snom 300 IP Phone
I have a snom 320 dialling out takes long time for connection
I guess this is a SIP phone , try dialling the number then add # at the end, a SIP phone does not know when you have finished dialling unlike a landline so # complets the dialling for you
Jul 12, 2012 | Snom 320 IP Phone
HOW DO I UNLOCK MY SNOM 300 KEYPAD?
To lock or unlock a Snom 300 keypad you will use the * key. Hold this down until the lock icon appears and hold down again until lock icon is gone to unlock.
Jan 14, 2011 | Snom 300 IP Phone
My snom 300 phone displays NR help please
try resetting the vlan settings if that doesnt work ensure that the default gateway and dns settings are correct.
Dec 08, 2010 | Snom 300 IP Phone
Cannot update firmware Snom 300
It's not really asking for a TFTP update, it's just something that is always checked for in the boot sequence.
As for manually setting the networking configuration rather than using DHCP, see page 14 of the manual at
http://www.snom.com/uploads/docu/UM_snom3xx_V2.2_en.pdf
for instructions on how to bypass DHCP and manually configure your settings.
Dec 22, 2009 | Snom 300 IP Phone
Hi, our phone here snom 300 cannot read the IP address what should be the best thing to fix this? thanks for the immeadiate reply.
How do you mean it cannot read the IP Address. Default is 196.168.254.2. Type that into a web browser and see if it connects.
Oct 22, 2009 | Snom 300 IP Phone
I forgot the password and cannot access the web interface of snom 300, version of firm ware is 7.3.23, I have tried to reset it but it again asks for password. I have tried user name as 'admin' and...
Your phone has two passwords, administrative and http. If you lose http but still have administrative you can fix this through the web interface as your are trying. If both are lost then you will have to reset the phone to factory defaults by using TFTP to update the frimware. Note that this will result in you starting from scratch with your configuration.
Here is the SNOM wiki article containing directions for doing this:
http://kb.snom.com/kb/index.php?View=entry&CategoryID=44&EntryID=32
Jul 02, 2009 | Snom 300 IP Phone
My snom 300 phone rebooted but displays NR
Go to vlan settings, then pick reset . The phone would restart itself and that should do the trick.
Jun 09, 2009 | Snom 300 IP Phone
How to change the IP address manually - through phone interface?
Go here for directions on disabling DHCP:
http://wiki.snom.com/Settings/dhcp
Once DHCP is turned off, you should have the option to manually configure the IP address.
May 25, 2009 | Hawking HWREG1 Repeater
Can't connect to phone
I bought SNOM 300 and i was unable to connect the router in first go. it was keep saying Send DHCP reqt but nothing was happening. i tried even connecting SNOM 300 dirctly to my laptop but in vain. in last i started receiving message Ethernet cable unplugged.
I reset the SNOM 300 to the factory defaults which solved the problem immediately.
Get to the phone menu "configuration-Reset" and select this option. it will ask for the admin password which is 0000. This will fix the issue. try it.
Jan 23, 2009 | Snom 300 IP Phone
Snom 300 IP Phone Logo
5,809 people viewed this question
Top Snom Computers & Internet Experts
David Payne
David Payne
Are you a Snom Computer and Internet Expert? Answer questions, earn points and help others
