I have a dell dimension PC and when I connect a non Dell Keyboard the PC will recognise any of (F) function keys I have tried a number of keyboards tat I know work on other PCs, reporting keyboard errors in setup is enabled and no errors are reported with any keyboard. Any ideas??
    Scholar:
  • 55 Answers
Try booting to Safe Mode and see if the problem still exists. Press F8 when you're on the Dell Screen and choose Safe Mode. If the problem does not happen in Safe Mode, then do this:
1. Click Start
2. Click Run
3. Type msconfig
4. Choose Diagnostic Startup
5. Restart to Normal Mode.
Posted on Nov 25, 2008
Hi my dell vostro key board has locked ,right hand side of keyboard blue light with a lock and 9 inside it .tried everything can you help
The 9 lock key means that your Number lock key is on. The blue light usually means that your blue tooth is on. Try connecting an external USB keyboard to see if it functions normally. If so then you need to have your keyboard replaced.
Jan 09, 2011 | Dell Vostro 1500 Notebook
Dell Dimension E510 - Keyboard compatibility
Hi, to find out if the “Keyboard is compatible with your system?” You can do the following: Shutdown the Computer, connect the Keyboard to your computer. Turn on the computer. If, the “Keyboard have a Power Button?”(Turn on) the keyboard. Go to, Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to Update Drivers! Click OK. Restart the computer. Check keyboards’ functionality. Thanks paul7of9
Jan 14, 2010 | Dell Dimension™ E510 PC Desktop
Some keyboard button not workin on dell laptop
Did you spill any liquids into the keyboard? If you did you may have damage the keyboard PCB and it will need to be replaced. One thing you can try to do is to first take a picture of the keyboard so you know where the keys go back to that you removed. Then use a small screwdriver to remove the non-functioning keys. Be very careful and do not use too much force or you may damage the key. Inspect the inner buttons and see if they are sticking. You can use a cotton swab or q-tip and rubbing alchohol to try and clean the inner part of the keyboard. Sticky liquids can cause the inner keyboard buttons to stick and mal-function. If the keyboard PCB is damaged you can either replace the keyboard or buy a usb keyboard to use on the laptop. The OS should recognize the keyboard after you plug it in.
Oct 13, 2009 | Dell Inspiron 1721 17" Notebook PC, AMD...
Same as above, with my laptop being studio XPS 1640
Well, as long as your pc is under warranty, Call Dell and have the keyboard replaced. it takes 24 hours to order the part, and 15 minutes to replace it. By this time tomorrow, you could be all set like a new 'vette. Good Luck!
Aug 31, 2009 | Dell D520 Notebook
The hot keys all work, but not any of the numbers, letters, f keys,
Hi there.
Download the driver directly to your PC by clicking on this link from Dells ftp site >>>>>>
ftp://ftp.dell.com/input/r89506.exe
Please post back with the results and thanks for using FixYa!!
May 21, 2009 | Dell Computers & Internet
During reinstall of XP on Dell Dimension 9100, half way through process the mouse/keyboard locks up and cannot continue with install. Any suggestions? Thanks.
Try using an optical mouse of the latest technology and maybe try a USB key board. Maybe this will make some difference.Try to use the most popular ones for starters...............sodeep
Apr 18, 2009 | Dell Dimension 9100 PC Desktop
Keyboard Error
Sounds like intermittent keyboard failure. If it is the old style keyboard connector (small round jack), shut down, remove it completely, and then plug it back in. If it is a USB keyboard, you are probably having USB keyboard support problems. Try moving the keyboard to a different USB port - usually the ones closest to the parallel port or network jack that are sure to be on the motherboard itself.
Hope this helps...
Nov 20, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 3000 keyboard error
hai pls enable usb option in cmos and then press f10 and then press yes and then restart and see . or else reinstall the usb drivers
Sep 08, 2007 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
